iCharger 406 DUO Charger >
Like Tree99Likes
Old 03-28-2014, 11:44 AM
  #16
Originally Posted by Grasschopper
Ok so you modified the connector...sure that works too. For $3 I figured I'd put the right connectors on mine.
Don't disagree at all, but it worked just fine. I was a little nervous plugging it in, but on the 308 thread, they confirmed the wiring.
Originally Posted by Odin544
The biggest concern is if you don't pay attention or someone else hooks your charger up for you and the balance connector gets plugged into the temp sensor port...... POOOOF! goes that channel. Why they used the same plug as a balance connector baffles me. I've seen several chargers get ruined this way so far.
Couldn't agree more! That's why no one uses my charger but me!
JiuHaWong is offline
Old 03-28-2014, 11:46 AM
  #17
idbdoug's Avatar
Trader Rating: 41 (100%+)
How are racers achieving more than a 10amp discharge? Considering 1 of these chargers and heard people are discharging at high amps using degenerative discharging
idbdoug
idbdoug is offline
Old 03-28-2014, 11:48 AM
  #18
Matt Trimmings's Avatar
Trader Rating: 171 (100%+)
idbdoug
+1. I need to figure this out too, the manual could be a little bit better.
Matt Trimmings is offline
Old 03-28-2014, 11:49 AM
  #19
idbdoug
idbdoug,
You will need to either hook up the charger to a full size car battery (regenerative discharging) or add some sort of resistor bank to the second channel (basically discharging from one channel to the other...I have yet to try this).
Or there is a stand-alone discharger (don't have the link handy) that supposedly works well.
Old 03-28-2014, 11:51 AM
  #20
Originally Posted by JiuHaWong
idbdoug,
wow...what kind of resistor bank do we need? I heard of some charging on one channel and discharging on the other channel to gain increased amps on the discharge. That is what the manual kind of explains, was going to try that later. You can also connect both channels to the battery and set to synchronous mode to gain a few amps.
Old 03-28-2014, 11:52 AM
  #21
Suspended
That's how you do it
PFKAOG is offline
Old 03-28-2014, 11:53 AM
  #22
Thanks, going to set that up tonight. You have to set it to regenerative discharge correct?
  #23
Suspended
Yep
PFKAOG is offline
Old 03-28-2014, 11:55 AM
  #24
Matt,
Check the 308 thread, there was a guy using one of the Integy Reactor discharger as the resistor bank. He basically gutted the electronics and hooked the wires to the resistor inside of the case. For only $20, it was a cheap way to discharge at 25amps.
Old 03-28-2014, 11:57 AM
  #25
Matt,
You would need to find one of those though...
Old 03-28-2014, 11:59 AM
  #26
try integy.com:
http://www.integy.com/st_prod.html?p...w#.UzXJXl5RfFY
Price went up! lol, it was $17 last I checked a few weeks ago. You might also be able to find one sitting in a hobby shop somewhere.
Here's some pictures to give you an idea of what you do with the reactor:
Old 03-28-2014, 12:10 PM
  #27
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
deleted
Wildcat1971 is offline
Old 03-28-2014, 12:14 PM
  #28
Suspended
Charging on one channel and discharging on the other channel to gain increased amps on the discharge works good and is easy. There's no need to buy more stuff if you have an old lipo laying around
PFKAOG is offline
Old 03-28-2014, 12:18 PM
  #29
Found the link to the standalone discharger:
http://www.racersmeasurementsystems....r-Dumper-W.htm
To date, I have yet to find any reviews on it.
Old 03-28-2014, 12:22 PM
  #30
deleted
