Lrp sxx issue!
Hey guys got a question. Got a lrp sxx speedo hooked up to a reedy Mach 2 17.5 motor. I was racing my main and it randomly had no throttle after a small landing. I have tried re soldering it and re programming it. I have steering but no throttle. It's really weird. When giving throttle the esc recognizes it. Any suggestions? Please and thank you.
Not sure if the lrp can run sensorless so check and try a different sensor cable maybe it went bad, after that check with a known working motor to eliminate which could be the culprit.
lrp's can't run sensorless, I'd replace the cable or check the sensor port on the motor / esc
Make sure you're voltage cut off is set to 2 cell. As a test turn it off and see if that helps.
Will try these things thanks guys
| All times are GMT -7. It is currently 01:48 PM. |
