-   -   receiver ID question (https://www.rctech.net/forum/radio-electronics/801157-receiver-id-question.html)
Jerry.T 03-19-2014 07:23 AM
3 Attachment(s)
Hello, I wonder if someone may recognize this receiver. The label say Serpent but the case look very Futaba. Need to know before I buy a transmitter and crystals. I have not found any images of an opened Futaba receiver, so I am lost...maybee someone recognize the circuit board?
TIA
Hoese37 03-19-2014 08:01 AM
Looks like a R133F.
Jerry.T 03-19-2014 12:48 PM
Originally Posted by Hoese37 (Post 13110988)
Looks like a R133F.
It does not fit the location of the crystal.
R153F and R203HF has the very same casing and both is as 27MHz FM.
That is why a think it is a Futaba but with a different label.
Hoese37 03-19-2014 07:45 PM
Most likely is a futaba.
Jerry.T 03-20-2014 12:08 PM
I appreciate your effort, but unfortunately it does not help. Yes, it most likely is a Futaba receiver rebranded. But searching this incredible place I have found some of the IC:s and the 455KHz quartz filter. The 31136G is used both for single and dual conversion but it should be one more IF quartz filter I think. So my guess so far is that it is a single conversion receiver wich will give the crystal to be used. The decoder IC I still have to find out but the cheapest guess is PPM.
