dx4s srs4200 rx issues
i have a stock losi rally x. i got a dx4s to use with it and now if i turn the remote off first i know not recommended but when i do the car takes off to full throttle. it never used to do it with the stock remote is there something i should know or do to prevent this. also is there and a site or recommended settings to make the avc work on the dx4s as well as it did on the dx2e. thanks
Use the SR4210 that came with the DX4S, not the 4200 that came with the car.....READ the instructions, bind it (failsafe should be automatic) and then you can utilize AVC.
Oh yea, and turn off the ESC 1st. Better get used to that. |
i usually do turn off the car first as most of them dont have on off switches but i forget from time to time. i did end up re-calibrating it and it worked this time no run aways.
thanks dan any ideas on what settings work the best for the avc on that menu in the dx4s menu |
| All times are GMT -7. It is currently 12:09 PM. |
