-   -   m11x help (https://www.rctech.net/forum/radio-electronics/800239-m11x-help.html)
dhunt488 03-15-2014 01:56 PM
m11x help
Got a m11x and when i try to change module setting from f2 to f3 it says model display only. Same when i try to change models. Doing it like the manuel says thanx in advance
mtpocketsracing 03-15-2014 03:39 PM
turn off the radio. now hold the display slide to the right until the display turns on. now you can change the setting.
it's a safety feature that prevents you from changing settings that will cause a car that is running or switched on from running off.
dhunt488 03-15-2014 03:52 PM
Thank you so much for that info. Did the trick. Gunna love this radio over my dx. No more glitching. Woohoo
