esc not powering up/bit of help needed
I just changed chassis on my 2wd buggy. After rebuilding the "new" car and trying to power up,my ESC will not turn on(no light on). I have tried to calibrate ESC and receiver with no luck. If I turn power switch on,my servo will turn on,but no power from ESC. Thanks for any help
ESC is Hobbywing V2.1 I also tried hooking up the HW program box,just says "connecting ESC" |
I got power now after disconnecting sensor wire. Plugged a new sensor wire in,same results. Motor will not turn under power with sensor wire connected.:confused:
You have motor wires connected correctly to the ESC? A-A, B-B, C-C?
Can you calibrate it without the sensor wire? |
Originally Posted by Yosh70
(Post 13088480)
Can you calibrate it without the sensor wire? Have not tried to calibrate without sensor wire. |
Tried a different motor? Could be sensor board on the motor....
Originally Posted by dan_vector
(Post 13089254)
Originally Posted by KAWIDAD
(Post 13089437)
I installed my other another 17.5 and all problems are gone. Looks like I will be replacing sensor board to try that out. Thanks for the help Yosh and dan
| All times are GMT -7. It is currently 09:10 AM. |
