-   -   Can a steering servo be too fast? (https://www.rctech.net/forum/radio-electronics/798426-can-steering-servo-too-fast.html)
JayL 06-02-2014 09:56 AM
servos are more than specs, they are also about feel.
If you try a Ko servo and any other brand except Futaba brushless, you will be blown away at how much feel you have. It is hard to describe unless you drive it
Salkin 06-02-2014 11:15 AM
I second that, had a Futaba brushless servo in my buggy, changed to a Team Orion servo because it was faster, but I eventually changed back to the Futaba servo because it just felt better. Hard to explain.
Salkin 06-02-2014 11:54 AM
I have talked to several of the best drivers in my country racing 1/8 buggy, and they said that going from at slow servo (above 0,11s) to a fast servo (under 0,8s) gave them more control and enabled them to counter steer in situations where a slow servo would not react fast enough.
My ST-RR EVO 06-03-2014 01:18 AM
Originally Posted by RDEERJOE (Post 13304864)
On a muggy, truggy ,mbx7te, would the 450 oz-in of signature series radio post servo be enough torque , I like the speed of .07 and if its too twitchy I could expo it out or slow it down with dx4s transmitter , its too bad that " protek 170t servo " is 630 oz-in but .11 for speed, until I read this post I thought that was fast, im thinking the radio post servo will have to do.
Originally Posted by kdeleon (Post 13305319)
I have that Radio Post servo and it is great. I was also worried that it might be twitchy but it is not. It is so smooth and responsive. I don't turn it down at all. I'm thinking of putting one in my other car.
+1 I'm running that Signature series as well on unregulated 2s lipo with a slightly longer servo horn which makes it even faster lol. Mega fast, smooth and powerful. It's in buggy. I know it'll be enough in truggy too.
RDEERJOE 06-08-2014 03:04 PM
Sweet, just ordered the radio post signature series.
Yosh70 06-08-2014 04:22 PM
I have had Savox and Hitec but decided to try out a Bluebird servo from HK for my D8 after talking to some of the fly guys in my area. The price was right, the specs were good and after installing a Castle BEC, one word....wow.
Some of you guys can say what you want about a Taiwan made servo, this thing is awesome.
http://www.hobbyking.com/hobbyking/s..._10ec_74g.html
Genebaby 06-13-2014 12:29 AM
My worry about those Hobby King servos is how long they'll last.
I have been using the Radiopost Red servo for over a year and it's been faultless.
RDEERJOE 10-19-2014 08:16 PM
I have raced all summer with the sig series in a mbx7te truggy , its not twitchy at all, and i agree with the "gets you out of a jam quick " i find it makes it easiervto correct drifts and geting completly side ways when you get rubbed and land all messed up, a quick right with some power and -'" BAM'"- you back in the race. Now all my other trucks seem sluggish, "" ps- it also helps when your truck can actually turn its wheels at high angle, bottom line..... radio post for me all the way!
murat61 10-20-2014 11:22 AM
Smoothness of a servo
Hey guys,
When the topic comes to good servo, i always heard how smooth radiopost servos are. So, i wondered and take a look at its specs from absolutehobbyz. Then, i realized those servos use 32 bit controllers which (i assume)makes them smoother than 12 bit servos like Savox due to significant increase in resolution. I again assume, it didnot make huge difference if you are using a slow servo under 0.15sec/60 degrees. However, as servo speed increases, rate of change in angle for each step input affects controllability of the car hugely from 12 bit to 32 bit. Therefore, people who uses very fast high resolution steering servo may not feel his car as twitchy as low resolution one.
Correct me if i am wrong.
mkorn 10-20-2014 03:46 PM
A servo that is too fast is perhaps the best way to make your car difficult to drive. I run our torque version servos and still slow them down with my radio. You can driver harder and mistakes happen slower.
You might be surprised how often an ill handling car can be fixed by simply slowing the servo down.
nikos2002 10-20-2014 06:15 PM
YEAH Marty!!!! Yes, a lot of times I watch guys with 1/8 all over the place on the track. They say "my tires are bad", "oil in the diffs are wrong", etc... its really that the servo is too fast, or voltage is cranked up too. A faster servo is only better if you can really use it properly. Some of us can not (I admit it - I have mine turn down to 70).
Frank L 10-22-2014 10:54 PM
I don't think the posted specs are all on the same level. If a servo had upwards of 500+ oz of torque then it should be very noticeable in the vehicle, from what I have seen they are not. Personally I trust KO and futaba, hitec a are great but their slow speed is an actual value.
wingracer 10-23-2014 04:58 AM
It would only be noticeable if the servo you were using didn't have enough torque. If it only takes 120 oz/in to move the wheels easily and accurately and you're using a 200 oz/in servo then a 5000 oz/in servo is going to make no difference at all as long as all else is equal.
iScream 11-09-2014 11:05 AM
Doesn't anyone use expo in your radio? I've been running a Protek 170S at 7.4 volts in my etruggy and like it so much that I just upgraded my ebuggy to the same servo this weekend. I was running an AE 1015 in the buggy. But I run some expo on both so I get a little more precise control around center but heavier corrections go from my hand to the front wheels as fast as possible.
-Chris
cdwilliams1 11-10-2014 01:11 PM
Originally Posted by Andy Koback (Post 13306384)
Lot of us on oval carpet pan car turn steering speed down to aid in handling.
:nod::nod::nod:
