-   -   Hyperion Charger making weird noises (https://www.rctech.net/forum/radio-electronics/798341-hyperion-charger-making-weird-noises.html)
CookieFlow 03-07-2014 02:24 AM
Hello! :smile:
I just bought my first charger (my 1st one came with my car) so I am not too used to how these work.
It is a Hyperion EOS 0720i.
I read the manual and started charging my first pack (2S//2200 Mah), it looks like its charging just fine but after 7,8 minutes the charger started making weird noises. This noise lasted maybe 1 minute then turned off and started again 8-10 minutes later and stopped again.
Is this normal? Also I noticed that sometimes the charge goes to 0A and then goes back to 2.2, again is it normal?
The charger also has cables that comes out of it from the side, from what I see in the manuel these can be tucked down in the back of the charger but it's a tight fit. Is it dangerous if the black and red cable touch themselves?
Thanks very much for the help guys! :smile:
racer1812 03-07-2014 08:30 AM
Originally Posted by CookieFlow (Post 13074243)
Hello! :smile:
Was the pack done charging? You have tone options, they may be set to tell you when the pack is done.
That's a normal part of the balance charging process with a Hyperion.
reply is in red.
ThePanda 03-07-2014 07:15 PM
what is the noise?
LasagnaCat 03-08-2014 04:39 PM
Fan?
