Blinky mode and ESC current.
Hi Guys, I race stock 17.5 blinky and I'm just trying to get my head around not so much the obvious part of blinky mode(no timing, reverse or boost) but the current rating of the ESC's.
I've got a HW Xtreme Stock which has a current rating of 60/380A where as the HW XERUN Stock Spec is rated at 100/600A. Does blinky mode have any impact on the current that the ESC can put out? In other words, would the stock spec be faster than the xtreme stock just because of the current it can put out? Cheers |
No. Current is drawn by your motor, not put out of the ESC. In theory, a 17.5 motor drawing xyz amps on ESC a will draw xyz amps ESC b; that's actually the point of blinky mode even.
Have done some tests on this and found:
VTA car 17.5 Blinky pulled 35-40 Amps on dead start (burst) average 7 Amps down a straight 4wd Buggy 17.5 pulled 35 Amps on dead start, averaged 12 amps on a straight So based on that a 35A Esc is plenty (as burst rating will be 100ish) The ESC can't provide more than the motor wants, the lower the motor turn the more amps it will pull (at least with 2 pole motors) |
So it'd only really be an issue if I ended up trying to go to Mod with the stock ESC?
Then what's the point of ESC's like the HW Stock spec and Orion Stock 100A? Meant for classes like 10.5 blinky or something? |
Originally Posted by ROB784
(Post 13036855)
A 30-40A Esc is plenty for Stock, I think people underestimate some of these 'lower end' speedies, I mean the Mamba Max Pro is only good for 80 Amps Constant.
(Post 13036855)
Originally Posted by MarkA
(Post 13036863)
Correct and correct. In fact, here in the U.S., many racers running 17.5/blinky are happy with the HW JustStock even: http://www.falconsekido.com/products...c-blue-edition
| All times are GMT -7. It is currently 02:21 PM. |
