How to store Lipo battery for 9 months? >
Old 02-02-2014, 12:29 PM
Trader Rating: 18 (100%+)
Default How to store Lipo battery for 9 months?
I'm deploying to Korea for 9 months. I have 3- Protek 7.4v 2s 2000mah lipo batteries, 1- Protek 14.8v 4s 2100mah lipo, 1- Protek 6.6v 2100mah LiFe. I would like to know what to do with these so that they are still good when I get back in 9 months. My charger is the Hitec X4 A/C Charger.
donbeatya is offline
Old 02-02-2014, 12:33 PM
wever75's Avatar
I would assume all you could/would do is a lipo storage. Maybe you want to do a lipo balance also so the cells stay balanced. Congratz on your deployment!
wever75 is offline
Old 02-02-2014, 12:34 PM
Hoese37's Avatar
Charge them on storage mode. Place them in some sort of metal or sealed container and store in a stable temp.
Hoese37 is offline
Old 02-02-2014, 12:39 PM
K thank you guys!
Old 02-02-2014, 12:53 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
store them at a little over 7.4 volts. they will slowly seft discharge.
store them separately. otherwise if one goes bad, then it doesn't ruin the others. nd store them in some heavy duty containers. (fire proof)
ThePanda is offline
Old 02-02-2014, 01:31 PM
Why store them in fire proof? Iwas thinking just thinking in Individual plastic containers with rice in them to prevent moisture from effecting them.
Old 02-02-2014, 01:34 PM
t2o
Default Freezer?
I stored several lipo's in the freezer for about 2 years.
The strong ones were still strong, and the weak ones were still weak, after they went back into service.
I put them in a zip-loc.
t2o is offline
Old 02-02-2014, 01:36 PM
Storage voltage (3.8~3.85V per cell), put them in a airtight container, tupperware/freezer bag etc (to prevent condensation) then store in the refrigerator. When taking them out allow for plenty of time for them to warm up, don't charge or run cold. Charge and discharge at 1C, then use. Or at the very least a dry and cool place.
Dave H is offline
Old 02-02-2014, 01:37 PM
Someone said put them in the freezer at half charge. I personally would charge them to 3.85v per cell. Of course it would be safer to store them in a fireproof container or bag.
KFXGUY is online now
Old 02-02-2014, 02:05 PM
Half charged is about 3.85V per cell.
7.4V, 3.7 per is only about 10~15%, seems kind of low to allow for a little self discharge.
Dave H is offline
Old 02-02-2014, 02:37 PM
ta_man's Avatar
Trader Rating: 168 (100%+)
Might have been me. I store my 4S LiPos like that over the winter (when I can't run 1/8th scale in New Jersey). Have some packs that have been in the freezer for 2 winters (and this will be the third) and still run great.
ta_man is offline
Old 02-02-2014, 06:35 PM
ThePanda's Avatar
just in case they go poof. since you are away, you can't do anything if they pop. better safe than sorry.
ThePanda is offline
Old 02-02-2014, 06:44 PM
Jim Hustins's Avatar
DO NOT STORE THEM AT 7.4V!!!!!!!!!!!!!!
Store them at 3.85v per cell for lipo. That is the most stable voltage and they will not discharge. For Life I do not know what the storage voltage.
Put them in a ammo box. If you have a fireplace that will not be used. That will be a great place to put the ammo box.
Jim Hustins is offline
Old 02-02-2014, 08:48 PM
I put mine at 3.85v every time they are going to sit for more than a day or two. May be a little anal. I also only balance charge my batteries every single charge. Ill go run the vehicle or boat, battery gets to cutoff I let it cool off then put it back at 3.85v. I may be over working myself, it still makes me feel better. Lol
Old 02-02-2014, 09:42 PM
ThePanda's Avatar
do you realize that the difference between 7.4 for a 2s and 3.85 (per cell) for a 2s is only a difference of .15 volts per cell? [3.7 vs 3.85]
and all batteries self discharge, lipo no different.
actually, it is recommended as a general rule to store lipo batteries at ½ charge. a charged lipo at 8.4 volts -6.4 for discharged = difference of 2. take ½ the difference and do 8.4 - 1 = 7.4 volts, which is ½ charge. though, for such a long time period, a higher voltage is probably better. so yeah, i don't know why you had a little flip right there...
maybe just know a bit what you are talking about...Im not starting a fight here, just providing actual information.
and if you read my earlier posts, i do say a bit above 7.4, to account for self discharge. (which is about 1% per month at 50% charge)
lets do the math again. 2 volts diff between charged and discharged (8.4, 6.4) is 2 volts 1% of 2 is .02 volts self discharge per month. 9 month absent is .18 discharged. 7.4 volts - .18 soft discharge is 7.22 volts (too low) so thats why i said a bit above. for the application, 3.85 is actually a fair bet to go with, as starting at 3.85, at the end of 9 monte, they will be around 7.35. for shorter time frame, a lower voltage (around 3.7) is just as good, if not better.
ThePanda is offline
