ESC & MOTOR START SLOW
Ok this is driving me nuts I am running hobby wing and hobby king ESC & MOTORS in my 2wd SC10.2's I have 3.
When hitting full throttle from sitting still the trucks will roll about 10-20 feet like it's at maybe 1/8th-1/4 throttle then will just take off and go until you get to a low speed corner or something where you slow way down they will do it again.
TROUBLE SHOOTING I'VE DONE
1 Tried 3 different radios
2 Tried 3 different esc's and motors
3 tried in another truck that runs fine to rule out drive line
4 Recalibrated radio and esc's
ANY IDEAS
ANY IDEAS
Sounds like a punch control setting issue
YUP Done that
yes even restored to default settings
did the expos
Another thing that it did I was just trying to keep it fast enough to avoid getting below the speed or rpm that it starts acting up and was fine if I did but I had to slow down for traffic by a jump and it wouldn't climb the face of the jump them it would roll back like I let off the trigger
now on 1 of the combinations I geared down 5 teeth and it was fine but it didn't run hot when it was geared higher, this is what I changed
69 spur 31 pinion
to
78 spur 29 pinion and this solved the problem for 1 setup
69 spur 31 pinion
to
