Futaba-R614FS questions >
Old 12-23-2013, 07:25 PM
Default Futaba-R614FS questions
I just picked up a really nice used Futaba-R614FS-24GHz-FASST-4-Channel receiver and 4PKS radio. Unfortunately though, I have no manual.
I'm about to plug everything all in, but I'm unsure which port on the receiver is throttle,steering or the port to plug the battery cable into. All of the ports are labeled 1 thru 4 with one labeled "b/c".
Any suggestions??
AsEpSiS is offline
Old 12-23-2013, 08:39 PM
canbarelyhover's Avatar
Steering is 1, Throttle is 2(from the esc if EP, in which case also the power).
canbarelyhover is offline
Old 12-23-2013, 09:17 PM
Cool! I'm not using an ESC since I run nitro. Do I plug the battery into the "b/c"?
Thanks for the replies!!
AsEpSiS is offline
AsEpSiS is offline
Old 12-24-2013, 07:13 AM
What I always use, 1 to turn two to burn
So 1 is steering, 2 is ESC/trotle.
Battery doesn't matter, I use channel 3 or 4 for my BEC, and they both work fine.
ruudxd is offline
