spektrum dx3s help travel adjustment >
Old 12-21-2013, 05:44 PM
Trader Rating: 64 (100%+)
Default spektrum dx3s help travel adjustment
hey guys I have 4 dx3s radio's
on 3 of them when I go into menu and select travel and then goto throttle when I click the scroll button and then turn it both forward and brake change % together if I push the throttle forward or back it then stays on either one depending where last pushed so you can just change the one not both.
the problem I have on the 4th radio is I have to pull the throttle down a bit before the square around the numbers will goto forward and allow me to wind it down or up its annoying as if I am slowing down a car for my son to use the car moves as I am trying to wind it down hope you all know what I mean I can't work out why it is like this.
michael
gnatsum69 is offline
Old 12-21-2013, 06:18 PM
Jerm13's Avatar
Trader Rating: 36 (100%+)
Check your trim step setting. It may be too high. Also make sure you have the throttle trim at zero when you bind the RX. This will make sure you have it right in the middle.
What kind of speed controller are you using?
Jerm13 is offline
Old 12-21-2013, 06:33 PM
hey there the trim is set at 0 the sub trim is fw 18. the esc shouldn't make a difference as it does it on all model choices in the memory and doesn't matter if the car is on or off.
in saying that it is a 45amp hobbywing esc on one car and the other is the std esc on mini 8ight
Old 12-22-2013, 08:38 AM
There is your problem. All throttle trims need to be at zero
kidcotton is offline
Old 12-22-2013, 01:25 PM
have have tried changing the sub trim to 0 and to 100 it makes no difference.
Old 12-22-2013, 07:25 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
You need to recalibrate the radio.
My 3R did the same thing.
racer1812 is offline
Old 12-22-2013, 08:14 PM
how do I do that?
Old 12-24-2013, 09:30 AM
Super Moderator
racer1812's Avatar
Scroll down the main menu to where it says calibrate, click on it. Then cycle the steering and throttle, all done.
Old 12-24-2013, 04:18 PM
your dx3r might have calibrate are u sure dx3s does? I cant find it in the menu.
