Hobbywing PC softwear help
Hey guys I'm having trouble with my hobbywing PC softwear. I'm trying to update my sct pro ESC firmwear, and i already have the 2 in 1 program box updated. So i hook up the speed controll port into the 2 in 1 program box ( the cable that connects to the reciver, not sure what it's called ), then i hook up the USB cable to my computer and my program box, then open the hobbywing softwear, then plug in the battery and turn on the switch. The program box says connecting to PC and the PC softwear just stays at the normal page, not responding to the ESC at all. I no the softwear is up to date Becuase it works with my program box. Help me please!
Bump, help?
Once the software is opened on the PC, click device at the top of the screen. Make sure you select "ESC Speed Controller", otherwise it won't read the ESC settings. Additionally, make sure that you connect the port that powers the fan to the 2 in 1 box, not the signal cable connected to the ESC that goes to the receiver. If you bought the ESC new, it should have been shipped with a servo extension cable - use that to connect the ESC to the 2 in 1 box.
Thanks so much! That was my problem, i didnt plug it into the fan port!
Punch controll help?
Hwy guys, I'm have trouble with my losi scte. I've got the hobbywing sct pro with the tenshock motor and a 14t pinion. The thing is when I gun it there's a ill bit off lag and it needs a seconds to boost up. Should I change any settings to help this like punch controll? Shoul i turn it up or down?
Originally Posted by wever75
(Post 12818909)
(Post 12819608)
Maybe you need a new gear i thought. Your motor is tenshock what?
| All times are GMT -7. It is currently 02:43 PM. |
