-   -   Sensored issues (https://www.rctech.net/forum/radio-electronics/778319-sensored-issues.html)
wever75 12-13-2013 06:43 AM
Sensored issues
Hey guys, I'm having problems with my ESC & motor in my scte. It's running at slow speeds like its sensorlesss ( cogging ), but once up and moving its very smooth. I'm running the hobbywing xerun sct pro with a tenshock sc411 4600kv, 14t pinion and stock 40t spur. Sensor cable also looks fine, should I be worried? The firmwear is V1.14_130508 i believe.
MarkA 12-13-2013 08:22 AM
Just as a matter of course, replace the sensor cable first. I've seen ones that look absolutely pristine cause issues.
lbenton 12-13-2013 12:20 PM
Or swap the ends between motor and ESC, it could just need to be seated in good... after that replace it ;)
brew99 12-13-2013 12:36 PM
HW updated the firmware for that ESC a week or so ago. Make sure you are using the newest, as apparently it helps correct HW/Tenshock compatibility issues (although, I'm not sure exactly what the issues were before).
