Hobbyking 120a Programming Card Problem
Hi everyone, I recently purchased two of these: http://hobbyking.com/hobbyking/store...nsorless_.html but I cant get this programming card http://hobbyking.com/hobbyking/store...150A_ESC_.html to work. When I plug it in the red led at the top lights up, but no numbers display on screen. Thanks for the help, Dropkinn.
I'm using HobbyWing card with this ESC.
The X-Car is meant to use the USB programmer.
There is one version of the software for the ESC that is meant for non-sensored motors. This software is able to work with the LCD programmer you have. The problem is, you need the USB programmer to flash over to that software. Long story short, order the USB programmer or see if a friend/track buddy has a USB programmer from a Brushless Hobbies ESC. I always recommend the X-Car to people who are on a budget, but I also always recommend to get the USB programmer as well!!! |
Originally Posted by dropkinn
(Post 12784588)
Good luck. |
I also tried this with a 60a esc I had lying around. It was correctly plugged in unless they marked it wrong, looks like I'm going to have to order the USB programmer. Thanks everyone!
| All times are GMT -7. It is currently 04:22 PM. |
