orion r10pro 1s-2s issues please help >
Old 10-30-2013, 07:03 AM
Trader Rating: 19 (85%+)
Smile orion r10pro 1s-2s issues please help
i just got the r10 pro 1s version for my 1/12 and i installed everything correctly ,calibrated the speedo with my transmitter and all seemed fine during bench test. i went to the local track to test last night and after approx 1-1 1/2 laps the speed light starts blinking and the car looses almost all power if you hold the throttle down after a 2 second delay the motor will kick in about 75% i cant figure this issue out if anyone can help that would be awesome thanks in advance..
AEcarpetracer is offline
Old 10-30-2013, 07:08 AM
and also the brakes are very very weak
Old 10-30-2013, 08:40 AM
MarkA's Avatar
Trader Rating: 21 (100%+)
The default brake setting is only at 75% - you will need to turn that up on the ESC.
For the other issue, what color is the light flashing? As well, did you try a different sensor cable? Most issues with the R10 will relate to it not getting a "clean" sensor signal.
MarkA is offline
Old 11-03-2013, 05:13 PM
I tried new sensor cable (2 of them) keep in mind I am running 1s and after 2 laps the light blinks green rapidly .. I got the brakes to work tho .. I need help
Old 11-03-2013, 05:14 PM
Bench testing speedo is fine only has issue once I putit on the track
Old 11-03-2013, 11:02 PM
BadPanda818's Avatar
Trader Rating: 18 (100%+)
turn the thermal protection off. some motors makes the esc thermal protection feature to act differently compared to other motors. hope this helps
BadPanda818 is offline
Old 11-06-2013, 11:27 AM
I tried this same result I'm gonna try a diff motor and hopefully it works
