-   -   Balance plug lead question (https://www.rctech.net/forum/radio-electronics/764895-balance-plug-lead-question.html)
PhoenixR1 10-14-2013 05:14 PM
I have an Onyx 245 charger, and I run a 22 and a 22SCT, both with Venom shorty packs. I've eliminated a connector in the battery to ESC harness and have run the pos/neg wires from the ESC directly to bullet connectors on the batteries. To charge, I simply use alligator clips on the pos/neg for each battery, and insert the balancing lead (mini-bullet). However, I need to keep the charger close to the car/truck due to short wires. So, here's what I wan to do: run an 18" pos/neg 12 gauge charge leads from the charger to the battery. Then, attached the balance board to the charger with double sided tape, then run the pos/neg balance leads from the balance board to the charge leads at the charger, rather than the battery. Finally, I'll have a long balance lead from the balance board to the battery.
Has anyone tried this? Any issues to be aware of?
Cliff notes: I'm moving the connection of the pos/neg balance leads from the battery side of the main charger leads to the charger side, then running a long balance lead along with the main charge leads.
Thanks for any input you can offer.
ThePanda 10-14-2013 07:12 PM
I have not done this personally. But I see no reason why it would not work. You would have to either splice directly into the wire, or attach the +,- at the connector solder joints that plugs into the charger. Only downside is it may not look as clean.
VenturaDC 10-15-2013 11:25 PM
All my balance connections are on the leads that plug into my charger and then I run 30" wires to my battery, works great. Makes for a clean setup having the balance board and all that stuff up near the charger and just running the 3wires out to the battery.
PhoenixR1 10-16-2013 12:49 PM
Great, that's what I was hoping to hear. Can you share a pic, if you don't mind?
VenturaDC 10-16-2013 12:52 PM
Sure thing, shoot me your email in a pm, rctech won't let me post a pix from my Android phone
VenturaDC 10-16-2013 01:10 PM
1 Attachment(s)
Edit. Here is the pic, had to text it to my work phone so it's way smaller then original, hopefully it clear enough.
asc6000 10-16-2013 03:03 PM
Get rid of balance boards altogether. The left plugs directly into the charger. The right goes to the battery.
http://i629.photobucket.com/albums/u...psc2fae750.jpg
PhoenixR1 10-16-2013 07:29 PM
Nice, thanks for the pics, guys.
theblitzkidd 10-16-2013 07:30 PM
If they don't sell those, I am sure making one is simple!
VenturaDC 10-16-2013 07:55 PM
Yep took all of 10min to put togther
theblitzkidd 10-17-2013 06:04 AM
Looks nice, and I bet it's worth every second of the 10 mins:D
neospud 10-18-2013 12:28 PM
There's a trick you can use. The only 3 wires that need to be long are the main + and - leads and the balance lead. Instead of connecting the balance +/- leads to the battery end of the cable i connect them to the charger end. Saves on a couple long 24g wires and makes it look more clean.
VenturaDC 10-18-2013 04:22 PM
You mean like the picture I attached above?
