Battery not balancing??? Hyperion voltage too high message
Hi all,
Just received a bunch of new formulax batteries direct from team trinity (REV2022-5). Out of all of the batteries, I received a shorty lipo that is slightly poofed. Checked the pack out of the box and it was a 7.7v, but cells slightly out of balance. This pack uses 5mm bullet connectors. I have a Hyperion E0606i charger, was worried since it was a little poofed, so I hooked it up to the charger for a balance charge. When the pack reach 8.4volts (about full charge), the charger sounds alarm - "Balance output voltage too high." Disconnect the pack, reconnect it and start the charge again and after a few seconds the alarm goes off again. Never had this happen on my Hyperion chargers with any battery. After the full charge and alarm, the cells read- Cell1 - 4.16v Cell2 - 4.20v Do I have a bad battery? |
Originally Posted by JourneyMan
(Post 12613972)
Hi all,
Originally Posted by Wildcat1971
(Post 12614055)
you bought a new pack that was puffed... RMA it. My packs are .003 v apart after charge, so .04 is kinda crappy.
They have an article on their website regarding puffed packs. To me that sounds like a charger issue though. I don't see why a charger wouldn't be able to further balance the pack. Try cycling it a few times.
Yea the article says they thoroughly check all lipos before sending them to make sure they're not puffed etc, I decided to try a "high end lipo" for the first time to see if there's a big difference, I run 2 trinity revtech 6900 100c 2s lipos and these are somewhere in the 150$ range, both will not finish charge anymore, they both used to balance properly etc, not anymore though and they get pretty hot while running and swell up, I had a SPC 6500 50c lipo that ran just as good as the trinity at under 50$
Many, many threads about the revtechs and puffing. RMA right away. Or at least attempt to.
I will take the advice and RMA this asap, since this battery has never been run.
It is significantly rocking on the table, out of five batteries this is the only one. No sense in cycling it through and have Ernie tell me it was used. One note - the Trinity website says they all get taken out of the packaging at Trincorp and puff tested. There should be a green sticker - do not have one, but I could clearly tell it had been opened. The first thing I do when I pull new batteries out of the box is used a lipo voltage checker to check the voltage of each cell and get a baseline. Thanks for all the advice! |
(Post 12614460)
Wanted to give you all an update for future ref.
So two things happened here - 1) Trinity determined my battery to be extremely poofed and approved an RMA. 2) The Hyperion charger is what is causing the batteries not to balance charge and produce the high voltage warning. I have two E0OS606i chargers - one with a blue backlit screen and one with the green backlit screen. The one with the green screen is a newer model ordered from maxamps. The older version of the two chargers is the one giving me problems. I have heard that you can upgrade the firmware, but do not know how to do this. I do not have any PC adapters to connect it to a computer. From experience - would you guys think I need to replace the charger or is this a known problem where I should look to upgrade the firmware? |
Do I understand correctly, the only battery that won't charge is one that is "extremely poofed"? If so consider yourself lucky that you have a charger that won't charge a battery that could cause problems.
I don't know if a 0606 can be user updated. Info can be found here 5.91 Firmware for EOS line chargers |
(Post 12661863)
when you power the chargers up, you should see the version on boot up.
(Post 12662511)
(Post 12676849)
It doesn't tell me the version on startup, just the charger model - Hyperion ES606i-AD. Also no menus or anything that might tell me the version.
(Post 12676890)
I looked and looked and looked. Conclusion. I dont think you can upgrade it. I recall that at one time some of the Hyperion chargers displayed that error and it was a "Bug". they later released a newer model that fixed the bug and also had 60% storage as an option. I think the color of the screen also changed.
| All times are GMT -7. It is currently 11:43 AM. |
