-   -   Which bullet connectors? (https://www.rctech.net/forum/radio-electronics/762766-bullet-connectors.html)
ntJeff 10-04-2013 05:51 PM
Need to solder some bullets onto an ESC, and I want some suggestions on bullets.
I like the ones you can solder flat, none of the tube stuff, anyone try these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXYXF3&P=7
It's for use w/ saddles in a B44.2, to give you an idea of what it'll look like.
Rc-bear 10-05-2013 04:47 AM
I use polymax 4mm bullets when I want tube bullets or that style if I want flat connections.
Easy to solder and if the become loose use a hobby knife to open the gaps up a bit.
ThePanda 10-05-2013 08:09 AM
Yes you always want the ones with the 4 pieces that form an x. Never the bird cage ones. They can flatten over time.
King DORK 10-05-2013 04:15 PM
I use the Duratrax ones listed in the first post. They're easy to solder and work great, and you can't beat the price. Been using them for several years so if you're interested in them, use them. You won't be disappointed.
IntegraMark 10-05-2013 10:09 PM
i use these. never had an issue with them
http://hobbyking.com/hobbyking/store...ile_10pc_.html
