Official Tekin RSX Thread >
Like Tree36Likes
Old 04-19-2018, 05:32 PM
  #1441
cobrajet's Avatar
Originally Posted by Randy_Pike View Post
Ok, a few things here.
Stock BEC voltage is 6v on all units.
Gearing a 2.5T motor 75/35 is not going to work, and the 66T spur will make it worse. If you're trying to dump the throttle with this setup you could be asking the battery to deliver over 500+ amps! I realize this is likely a high speed car, but you'll need to roll on the throttle a little bit here.
Understand that the ESC has NO control over the steering aside from powering the BEC. If you're amping out the battery in this manner, the BEC may get a ripple current through it the receiver cannot handle. A receiver cap may help squelch the noise and cure this, but the gearing you're trying to run isn't sustainable.
That makes alot of sense, And I was having issues with just rolling the throttle, I think the smallest i can go is 75/23, I'll see what happens and if i can make it work or just save this set up for a real touring car. But I guess we can rule out the motor and esc and I do thank you for all your help.
Randy_Pike likes this.
cobrajet is offline
Old 05-11-2018, 12:43 PM
  #1442
Question for Randy. (sorry if this has been asked before)
I'm hearing other ESC brands are testing with very low drive frequencies for stock class racing, like in the 1000Hz range.
Will the RSX be capable of these low frequencies?
Would this be an upcoming firmware update?
thanks,
lawton70 is offline
Old 05-11-2018, 11:08 PM
  #1443
Team Tekin
Randy_Pike's Avatar
thanks,
Maybe, We go down to 2khz now and so far have not found a reason to go lower. We easily can as our hardware supports much lower frequencies if we need to go there. One of the best things about Tekin is that we are often way ahead of our competition when it comes to hardware. This allows us to offer free as needed software adjustments to bring your ESC up to the highest level with a few mouse clicks.
Casper, lawton70 and Talon4U2NV like this.
Randy_Pike is offline
Old 05-14-2018, 02:18 PM
  #1444
Casper's Avatar
Trader Rating: 34 (100%+)
Back in the brushed days (so not sure if still applies) but really low freq usually increased heat.
Casper is offline
Old 05-14-2018, 09:11 PM
  #1445
Team Tekin
Randy_Pike's Avatar
The theory can be the same but we don't see it typically.
Old 05-15-2018, 08:59 AM
  #1446
Casper's Avatar
ok. thanks for clarifying. Back in the day with Keyence brushed ESC's we could run really low freq and cook a brushed motor. I have been running in the lower range with the tekin stuff and not had any issues just not sure if there was a "breaking point" in the brushless world.
Casper is offline
Old 07-04-2018, 07:11 PM
  #1447
Is there any harm on releasing a firmware that will run at these low frequencies so tekin racers can run them if they feel the need?
lawton70 is offline
Old 07-05-2018, 11:09 PM
  #1448
Team Tekin
Randy_Pike's Avatar
Potential harm...not likely. But I'd have to see lap time improvement to spend the $$ to make the change and get ROAR approval for it.
Edwin Pibal and Talon4U2NV like this.
Old 07-12-2018, 12:42 PM
  #1449
Tech Legend
Cain's Avatar
Trader Rating: 252 (100%+)
Running a brand right now that advertises a 32bit CPU and does the frequency down to 1000Khz.
They state that lower frequency will give it more agressive throttle feel and less overall RPM. Going the other way does the reverse and increase heat in the ESC.
One thing I was curious about was does it also increase (when you go to a lower frequency) heat in the motor?
Playing with the setting for that brand it does fee more punchy.
For the Tekin RSX versus that RS Pro Black edition, which one would be better for 17.5 stock 2wd buggy, and also for 1/10 4wd open?
I don't have a smart phone, so is there a cheap tablet you guys recommend to grab for adjustments?
Cain is offline
Old 07-12-2018, 03:50 PM
  #1450
Casper's Avatar
RS Pro BE for 17.5 and RSX for mod 4wd. As Randy always says get the right tool for the job.
According to the play store the tekin hotwire app will work on any android OS 3.1 to 7.0. You can attach using USB cable or Bluetooth (BLE) compatible device if you have the Hotwire 3.0.
https://play.google.com/store/apps/details?id=com.teamtekin
https://www.amazon.com/s/ref=sr_st_price-asc-rank?keywords=android+tablet&rh=i%3Aaps%2Ck%3Aandr oid+tablet&qid=1531432302&sort=price-asc-rank
Cain likes this.
Casper is offline
Old 07-13-2018, 06:55 AM
  #1451
Talon4U2NV's Avatar
I run an RS Pro BE in my EB410 13.5 Stock indoor clay car and also have an RSX running in another EB410 indoor carpet car with a 13.5 in it
Honestly; if you stay stock class, the RS Pro BE is perfect... I got a screaming deal on my RSX off here and did it and when i land an ET410 when and if
that arrives... the RSX will goto that and I will put and RS Pro BE into the carpet buggy. RSX does weigh a touch more than the RS Pro BE FWIW.
Talon4U2NV is offline
Old 07-13-2018, 09:07 AM
  #1452
Tech Legend
Cain's Avatar
thanks for the info!
Using an EB210 conversion, maybe the RSX all around would be best as a layout change of the electronics thinking of moving them forward on the chassis, plus, some talk about mod class in the future.
Also an ET410 (maybe changed to a ET210) is in the cards here too
Anyway thanks for all the info!
Talon4U2NV likes this.
Cain is offline
Old 08-28-2018, 12:15 AM
  #1453
Anyone is using the RSX in touring cars ? how about the experience ?
Edwin Pibal likes this.
Guatott is offline
Old 08-28-2018, 03:25 PM
  #1454
Team Tekin
Randy_Pike's Avatar
Plenty of people do.
Old 08-28-2018, 04:43 PM
  #1455
Casper's Avatar
Many of the great advanced braking features of the RSX and smooth throttle will make it a great TC ESC. Tekin top of the heap in the onroad world.
Casper is offline
