Official Tekin RSX Thread >
Like Tree69Likes
Old 05-22-2015, 10:26 AM
  #826
Originally Posted by Randy_Pike View Post
Email [email protected] with a copy of your proof of purchase and they'll send you one.
The part# is TT3520. The cap that is included is superior to anything Spektrum is offering.
I'm racing this weekend. Is there something suitable that I can pickup from an electronics stores?
aggie4231 is offline
Old 05-22-2015, 10:33 AM
  #827
Team Tekin
Randy_Pike's Avatar
Look for a 16v 1000uf cap. Radio shack has them. It'll get you buy for now but I recommend getting the right ones as soon as you can.
Randy_Pike is offline
Old 05-22-2015, 10:44 AM
  #828
Suspended
Randy can you please please please pop into the B5M thread and educate everyone why the throttle EPA needs to be at 100?
Mantis Toboggan is offline
Old 06-01-2015, 10:45 AM
  #829
vito's Avatar
need hlep i miss take cut the on and off switch off how do i fix it
vito is offline
Old 06-01-2015, 11:06 AM
  #830
Team Tekin
Randy_Pike's Avatar
How much lead is left?
Old 06-01-2015, 11:11 AM
  #831
vito's Avatar
and 1 inc left
vito is offline
Old 06-01-2015, 06:48 PM
  #832
vito's Avatar
can i by pass the switch?
vito is offline
Old 06-01-2015, 09:34 PM
  #833
Team Tekin
Randy_Pike's Avatar
and 1 inc left
Ok is that enough for you to use on your car?
You can bypass it if you'd like.
Old 06-02-2015, 06:53 AM
  #834
vito's Avatar
was trying to move it i cut the wire by misstake
vito is offline
Old 06-14-2015, 06:20 PM
  #835
Hey I have a question To see if someone can help me out . I'm running a rsx and gen2 6.5 motor in my d413. I have 21/72 on gearing . Now I'll be ripping laps on our track and after a lil bit of driving the car will just all of a sudden turn off , then u can hear the esc recalibrate (go threw its beeps like when u first turn on the esc) then the car will go till it decides to do it again. Is this a heat issue ? I've check the onboard temp and the lights have not been all lit up so I'm not sure as to what it is .I'm trying to figure out what I need to do to fix the problem any help will be greatly appreciated
Dave
daviboy is offline
Old 06-14-2015, 07:30 PM
  #836
STLNLST's Avatar
Trader Rating: 27 (100%+)
Originally Posted by daviboy View Post
Hey I have a question To see if someone can help me out . I'm running a rsx and gen2 6.5 motor in my d413. I have 21/72 on gearing . Now I'll be ripping laps on our track and after a lil bit of driving the car will just all of a sudden turn off , then u can hear the esc recalibrate and the car will go till it decides to do it again. Is this a heat issue ? I've check the onboard temp and the lights have not been all lit up so I'm not sure as to what it is .I'm trying to figure out what I need to do to fix the problem any help will be greatly appreciated
Dave
What settings are you running on your speedo along with motor timing?
STLNLST is offline
Old 06-14-2015, 08:42 PM
  #837
ekt
ekt's Avatar
Dave
Do you have wires hanging over the buttons?
ekt is offline
Old 06-15-2015, 01:00 PM
  #838
I'm running it with no timing on esc and motor , the buggy is plenty fast with none . I have a 2s smc shorty battery aswell and I'm running a spektrum 6040 servo ,If any of that helps
daviboy is offline
  #839
No I did check that already
daviboy is offline
Old 06-15-2015, 07:20 PM
  #840
HulkNT1's Avatar
Helping with this question please about ESC and its cooling fan. Should I let the ESC fan turn off by itself before I disconnect the battery after finishing 5 min run or is it ok to disconnect the ESC and let it cool down.. I have a friend that state I should let the ESC fan turn off by itself meaning the esc is cool and it is safe to disconnect the battery what your take on this.. I place it here not to make another thread.
HulkNT1 is offline
