Official Tekin RSX Thread >
Like Tree60Likes
Old 01-26-2019, 05:47 PM
  #1531
platgof's Avatar
I really like all my RSX esc's, and they always perform great.
platgof is offline
Old 02-03-2019, 12:33 PM
  #1532
oldernoob's Avatar
I have two RSX and I'll definitely get the Pro as soon as I can get one. Is it lower resistance (fet spec) than the normal RSX? I only ask as I'll be using it for mod and stock.
Someone mentioned dual mode keeping the ESC cooler but decreased punch feel. Apart from lowered drive frequency is there anything else to get the most out of stock motors (17.5)? I assume that straight sensored mode is better in stock??
oldernoob is offline
Old 02-03-2019, 07:09 PM
  #1533
Tech Legend
Cain's Avatar
Trader Rating: 253 (100%+)
If you mean items that affect punch feel looks like these items are ones to look into:
- Torque Level
- Throttle Minimum
- Throttle Frequency
Information on each setting can be seen here:
https://www.teamtekin.com/updateguide.html
Hope that helps!
oldernoob likes this.
Cain is offline
Old 02-03-2019, 07:39 PM
  #1534
oldernoob's Avatar
Krio mentioned something:" If you run in Dual Mode instead of sensored only, you will notice a big decrease in ESC temps. The motor won't be quite as punchy, but it's a small trade off. Before the RSX, I had an RS Pro in my B44 with a 6.5. and had no problems in Dual Mode."
It was this I was thinking about. I'm already running at 1Khz etc, but thanks for the response I'll check the other settings anyway.
Old 02-03-2019, 08:34 PM
  #1535
Krio's Avatar
Trader Rating: 152 (99%+)
Sensored only mode definitely provides more power as you are able to use more timing on the can of the motor than what is available in dual mode. Dual mode isn't allowed in stock racing anyways as it doesn't qualify as blinky mode.
Krio is online now
Old 02-08-2019, 12:21 PM
  #1536
oldernoob's Avatar
Ah, ok. i was wondering why i couldn't see the dual mode option - i had timing set to blinky!
Old 02-09-2019, 09:31 PM
  #1537
Ostach24's Avatar
Trader Rating: 90 (100%+)
Excited to see the Rsx pro is in stock at amain
Ostach24 is offline
Old 02-12-2019, 07:19 PM
  #1538
What changed with the Pro?
- fets
- wire posts
Anything else?
Jeff_S is offline
Old 02-13-2019, 04:45 AM
  #1539
- fets
- wire posts
Anything else?
Really ?
one page back
freebird likes this.
chuck_thehammer is online now
Old 02-14-2019, 09:02 PM
  #1540
BryanAZ's Avatar
I am currently running a 17.5 Team Powers motor that I cannot adjust the can timing because the screw heads on the motor are stripped. Can someone explain the timing profiles on the ESC available via hotwire? I just changed it to timing profile 3 to get some more speed since I am not racing at the moment, just practicing at the track, so I donít necessarily need to be in blinky. Also, should I put the fan back on, or should it be safe without it? Probably put it back on just to be safe. Anyways, thanks in advance!
BryanAZ is offline
Old 02-14-2019, 09:49 PM
  #1541
The timing profiles add boost into the ESC IAW the specs listed below. This timing will be in addition to any static timing on your motor. You may need to add the fan to the motor; if you were at 30* motor timing you will be at 55* timing at the end of the boost program and may be making a lot of heat. When running boost the preferred setup was to lower motor static timing to account for boost advancement of the timing. Check your motor temps often to make sure you are not overheating the system.
TP1: Spec Stock "blinky mode" 0*timing boost
TP2: 15* Timing Boost / RPM Range 5443-20,016
TP3: 25* Timing Boost / RPM Range 5443-20,016
TP4: 35* Timing Boost / RPM Range 5443-20,016
TP5: 45* Timing Boost / RPM Range 5443-20,016
BryanAZ likes this.
sweems is offline
Old 02-15-2019, 05:23 AM
  #1542
dremel the screw heads to make a slot.. use a common screwdriver to remove them.. get new screws.. FIXED.
if no dremel.. go to track early on race day. someone will have one and can easy do it..
Old 02-15-2019, 09:54 AM
  #1543
BryanAZ's Avatar
I do have a Dremel with a cutoff wheel, so I might try that. The screws are absolutely tiny, so might be a little difficult to dremel a slot into the heads and I donít know where to get replacement screws. Also, the motor is quite old and nothing special, so I might just get a new motor! Good excuse to get one!
chuck_thehammer likes this.
BryanAZ is offline
