-   -   What esc to use? (https://www.rctech.net/forum/radio-electronics/761026-what-esc-use.html)
shauny2036 09-26-2013 12:30 AM
What esc to use?
Hey I recently bought a 17.5T sensored venom motor, I have a Losi esc that supports sensored motors. now it came with a 22 rtr I once owned and was running a 13.5T motor, can that esc run the 17.5T I have? If not what esc do I need to buy? Thanks.
Dave H 09-26-2013 03:29 AM
Should be able to. A 17.5 should use less current than a 13.5.
asc6000 09-26-2013 08:30 AM
yup, bolt it in, it is a slower motor so you will want to change your gearing, probably add 3-4 teeth to the pinion, you can then race in the stock class with the 17.5 and use the 13.5 for mod or open.
Dave H 09-26-2013 04:30 PM
Just to add, it's a lower turn motor that you need to be careful with. In general a lower turn, like a 8.5 for example, will use more current, depending on the ESC may burn it up. The ESC should have a minimum turn rating specified.
If you have this one it lists a 13.5 turn limit for example. Although it's not real clear on the minimum part.
shauny2036 09-26-2013 06:50 PM
Awesome thanks guys
