HELP choosing a servo for 1/10 buggy 4x4 ?
I just got my losi 22 2.0 and i was wondering which savox servo would be the best I was looking at the digital brushless high speed can someone help me out please ???
That's a powerful servo for a buggy. Go for high speed, reasonable torque. You could save some money.
Hitec 7955 or 7950
I'll take high torque over high speed every day of the week. |
Originally Posted by ThePanda
(Post 12520487)
Here is some good info that should get you started.
http://www.futaba-rc.com/servos/digitalservos.pdf |
Anything around 130oz and less than .10 would work fine.
If you are already running Spektrum the 6040 is good.
http://www.spektrumrc.com/Products/D...odID=SPMSS6040 I plan to put the Orion Vortex VDS2-HV 1605 in my 22 2.0 http://www.teamorion.com/vortex-digi...ervo-en-2.html I believe high voltage is a reference to being tuned to current lipo 7.4v packs, although there is probably more to that. |
If it is a high voltage servo it means it can operate at higher voltage. In a lightweight buggy anything relatively fast will be just fine
Like stated above, standard servos are rated to only work at 6v but high voltage servos are rated to work at 7.4v. Most ESC's built in BEC only put out 6V though but still not a bad idea to have IMO.
I WANT THIS ONE Savox SB-2271SG "High Speed" Brushless Steel Gear Digital Servo (High Voltage)
[SAV-SB-2271SG] MAP Price: $124.99 |
Originally Posted by RCNITROFREAK06
(Post 12522504)
Originally Posted by ufoDziner
(Post 12522568)
I run those in our 22Ts. They are fantastic.
(Post 12522593)
So it's not over doing it ?
I also prefer to run the same model servo in all my stuff in case I need to swap them around to test or "borrow" one from another one of my cars at the track. |
(Post 12522593)
Originally Posted by Lason
(Post 12522606)
After you strip a couple cheap servos or find your RC pushing in corners due to lack of servo torque then you'll figure out there is no such thing as overdoing it. I'd rather have too much than not enough.
| All times are GMT -7. It is currently 07:24 AM. |
