Originally Posted by Kebabkongen
(Post 12498573)
So I have a Muchmore PS rated at 2x22A @ 12V, how much will I be able to charge with using this charger?
can anyone tell me where i can buy parts for my icharger 4010? i broke the little flat blue port peice on the front and need a new screen housing.....thank you... im in US
I'd be surprised if they sold individual parts for ichargers. However, if they did, http://www.progressiverc.com would probably be your best bet. Give them a call.
(Post 12498573)
Using one 22A at maximum voltage it should be able to achieve around 15 amps each on a pair of 2S lipos. Half on 4S, etc. Perhaps a little less to not push the power supply to the max for a little headroom and better reliability. |
Originally Posted by silencery
(Post 12502792)
Thank you. And yea thats what im afraid of. Im hoping somone might see this thread and chime in with good news. Ill call progressive. Thank you again |
Syndrome posted this in another thread, it shows the size difference between the 4010 and the 308
http://www.rctech.net/forum/attachme...uo-4010duo.jpg |
Any reviews on this charger?
Originally Posted by vabroom
(Post 12534253)
Originally Posted by JiuHaWong
(Post 12536399)
Check the battery/charger forum on rcgroups.
Originally Posted by Grasschopper
(Post 12536457)
Do I really have to weed out the 308 info from the 308/4010 thread?
http://www.progressiverc.com/the-sur...00w-combo.html
Decided to take the plunge from a Radioshack PS and my old Duratrax ICE. Here's to hoping I like it. :) |
Originally Posted by jamesbernatchez
(Post 12595508)
Decided to take the plunge from a Radioshack PS and my old Duratrax ICE. Here's to hoping I like it. :) I have a similar setup but my PS is an Alinco 32A used for ham radios. That description is misleading because it rates the PS at only 36A but it says you can charge 2x 2s packs both at 30A simultaneously which should be a 60A load on the PS which imeans there's 24A of phantom juice? |
....made my own charging lead. I only charge 2s packs so I ditched the balance board.
Originally Posted by Racing4Evo
(Post 12596197)
Nice!
I have a similar setup but my PS is an Alinco 32A used for ham radios. That description is misleading because it rates the PS at only 36A but it says you can charge 2x 2s packs both at 30A simultaneously which should be a 60A load on the PS which imeans there's 24A of phantom juice? Switch mode also allows the charger to handle batteries at a higher voltage than the supply, then more current would be required instead of less. Older linear mode chargers did have that limitation, they only reduced voltage, required the same supply amps as the charge rate. Would get very hot with high supply voltages, couldn't charge higher voltage packs, etc. Nice setup. Almost bought one of those Alincos once, looks like a sweet supply. |
| All times are GMT -7. It is currently 12:52 AM. |
