Which radio to keep....EX-10 Helios or Futaba PLS
Which is a better radio as far as the technology goes & quality?
I have both and both are comfortable, just not sure which one to keep. Ok first I have the older Ko Propo EX-10 Helios with the RF-901s module & KR-408s Rx. It's been a great radio for a long time. Next up I have the Futaba 4 PLS system with the R304SB Receiver I know the Futaba is a newer radio with newer technology but is it really any better? Thanks for your time.... |
I vote futaba!;)
Do you need 4ch?
If not, the EX-10. |
No need for 4 channel, I just run 2wd buggy.
Anyone know if either one uses different technology? Does one have a bigger advantage on the technology side? The EX-10 is an oldy but a goody & the PLS in new..... |
Helios was a top dawg back then. The 4PL is a bit newer so I'd keep the Futaba too.
Thanks I am kind of leaning towards the new Futaba PLS.
Thanks for the reply.... |
From a radio channel allocation perspective, and technology ability to avoid interference you're looking at:
AM < FM < PCM < DSM < DSM2 < FHSS < S-FHSS < FAAST Being that the technology used in both radios you've outlined (assuming the EX10 has the Ko Propo 2.4 module), then both are S-FHSS and technologically similar. If the EX-10 is the FM version then there's no question. The EX10 though has a slower CPU, but unless you've been able to notice it I wouldn't count that against it. The lag probably isn't perceptible. Lengthy technical article if you are inclined: http://www.rcmodelreviews.com/spreadspectrum01.shtml |
Originally Posted by cdwilliams1
(Post 12462781)
AM < FM < PCM < DSM < DSM2 < FHSS < S-FHSS < FAAST Being that the technology used in both radios you've outlined (assuming the EX10 has the Ko Propo 2.4 module), then both are S-FHSS and technologically similar. If the EX-10 is the FM version then there's no question. The EX10 though has a slower CPU, but unless you've been able to notice it I wouldn't count that against it. The lag probably isn't perceptible. Lengthy technical article if you are inclined: http://www.rcmodelreviews.com/spreadspectrum01.shtml Yes, it's the 2.4 ghz with the KO Propo RF-901s module. Thanks for the article... |
Id vote ko.... had mine for many years and never a problem
I now have two Futabas and I just love the feel of them in my hands. Plus newer is always better right? ALWAYS. Zero exceptions. Ever.
/sarcasm But I'd still say keep the Futaba. |
Why not keep both, have one as backup?
| All times are GMT -7. It is currently 02:15 AM. |
