-   -   Novak Havoc Pro issue ?? (https://www.rctech.net/forum/radio-electronics/751697-novak-havoc-pro-issue.html)
stulec52 08-15-2013 06:29 PM
Hey guys and girls, I have a Novak Havoc Pro in my SC10 running a 9.5 in it.
it never got hot or shutdown or anything, but it has developed a weird fault I wonder if any of you have had.
It'll run just fine, but about every 20-30 seconds, it shuts down for a about a second or so.
No power, and no brakes either, but I do still have steering.
I swapped it other with another speedo without changing anything else and the problem goes away, so I am sure it's the speedo.
Anyone ever had or heard of this?
Could it be just the power cap?
or is it pooched??
many thanks
Stu
kingofcool999 08-15-2013 06:32 PM
or is it pooched??
many thanks
Stu
Does it flash any error codes on the LEDs?
stulec52 08-15-2013 06:54 PM
Ah yes, good question.
After going through setting up all the lights read no faults.
I did previously have a flashing green LED but that turned out to be a motor sensor board fault.
kingofcool999 08-17-2013 07:12 AM
I've had similar issues... Try to get a look at the LED's right when the issue happens. My bet is that you are getting a brown-out, and the ESC is shutting off for a second. If that is the case, the red and yellow LED's will blink a couple of times after the ESC shuts off and is starting back up. My truck did this after a hard landing, wreck, etc. when the steering servo would draw a lot of amps trying to keep things in line (drawing more amps than the BEC can hope to supply). You don't happen to use a Savox servo, do you?
stulec52 08-17-2013 06:56 PM
KO servo.
We looked for LED flashing and couldn't see any, although it is possible.
Thanks for the ideas, I'm not sure what to do with it now though, as its a perfectly good speedo, but l one out of warranty and I don't know where to get it repaired.
clodtruck 08-19-2013 08:26 PM
Replace the capacitor on the esc. Same thing happened to my brother. The wires came unsoldered underneath the shrinkwrap.
stulec52 08-20-2013 12:10 AM
That has to be worth trying for sure.
Thanks !
