Futaba 4PLS Radio Binding Issues >
Like Tree1Likes
Old 06-29-2019, 06:15 PM
  #16
Billy Kelly's Avatar
Originally Posted by xjwolfpacker View Post
I'd recommend doing a factory reset on your radio first. Then once all settings are back to default, try binding again. Also, are you sure your ESC wires are in the right orientation/order?
Iíll have to look into the reset. Havenít been suggested that. Servo in 1, esc in 2. I was a little suprised to not see a positive/negative marking on any of the receivers.
Billy Kelly is online now
Old 06-30-2019, 08:51 AM
  #17
Trader Rating: 35 (100%+)
For Futaba receivers, the correct order for the servo/esc wires is always white/red/black. White is always to the "inside", and black always to the "outside". White is your signal wire, red is power (+) and black is power (-). Depending on the brand of servo or esc, you might have a yellow or orange wire instead of white, but it's the same thing. You may also need to reorder the wires in the actual plastic connector if they are not white/red/black.
Example:
xjwolfpacker is offline
Old 07-01-2019, 04:45 AM
  #18
Example:
Thanks. They were plugged in correctly. Considering how many times Iíve switched receivers itís more the possible that it could have happened. I did find that a piece of dust was stuck in on esc plug port. It could have been the problem. Could have happened recently. So one receiver is now working. Iíll have to try again with the others.
