-   -   New Charger Recommendations (https://www.rctech.net/forum/radio-electronics/747869-new-charger-recommendations.html)
BIGSKI15 07-29-2013 06:13 PM
Yes, i've searched...
My son is now at the age that he is going to start racing with me. I race 2-3 classes a night and will now have him racing with me.
I currently have an onxy 245 and have been wanting to upgrade anyway. I'd like a charger that will charge 4 batteries at one time. Currently, i run all 1/10 scale but will eventually get into 1/8 scale as well.
I don't need the top of the line but i don't want junk either.
What are your thoughts on the hitec ac/dc plus x4? I'm open to other options too.
Hoese37 07-29-2013 07:16 PM
Ive SEEN too many Hitec X4s just randomly quit working. Either the screen just quits or gives "Voltage Error" message. You could look into something like the 400X2. Its only a dual charger, but you could double the charge rate and get the packs done in half the time.
deeretrax 07-29-2013 07:41 PM
These guys put together some combo units that have nice portability.
http://www.progressiverc.com/chargers/charger-combos
ThePanda 07-29-2013 11:42 PM
i don't really see the point to these...
HawaiiBob 07-30-2013 01:35 PM
There are other options that are as good or better and less expensive. The ichargers are excellent, but the power supplies can be found cheaper if you look around.
Dave H 07-30-2013 02:51 PM
If you want to get into electric 1/8 scale, consider getting something with more than the common 50 watts per channel. While a 50 watt charger like the ac/dc X4 will charge a 4S, it will be slow, around 3 amps. Suggest at least 80-100 watts or so.
apriliamille 07-30-2013 03:11 PM
maybe the x4 80?
but id be looking for larger and in the dual port capability.
either the icharger dual, the tp820, a hyperion
having the dual port is nice. the other night i was charging my transmitter battery on one port while doing the starter box on a 2nd port. then i hooked up 2 electric car batteries on the ports and got them done in about 20 minutes
or wait a month and get this bad boy
http://www.usastore.revolectrix.com/...ual-PowerLab_4
Dave H 07-30-2013 03:17 PM
Yikes! Twin inputs to overcome the AC outlet limitation. This I can charge all my batteries faster that you thing is getting out of control. :lol:
JiuHaWong 07-30-2013 07:33 PM
Originally Posted by apriliamille (Post 12398428)
maybe the x4 80?
Interesting...So this bad boy is basically two PL8's in one.
:lol: We'll be up to 1.2 gigawatts within two years. :D
kcobra 07-30-2013 08:11 PM
Not real impressed by the looks of that PL8x2 unit. Looks like to me they just shoved two PL8's in one case. Price though is a good bit cheaper than buying two PL8's so that is a plus. As far as form goes for a duo charger, the iCharger 4010Duo is a lot more polished. No doubt though the software interface of the PL8x2 will be much better though.
For a car guy, the best bang for the buck charger is the Hitec 400x2 charger. After tower coupon it can be had in the $160 range.
BIGSKI15 07-31-2013 07:03 AM
I may go the hitec route mostly to save money from buying a power supply if i were to purchase a dc charger... im just lost in searching all the pros and cons of so many chargers... haha
ThePanda 07-31-2013 09:03 AM
if you want the best at no cost go with revoelectrix (or howerver you spell it) does everything you could want from a charger
apriliamille 07-31-2013 06:08 PM
but do think about the 1/8 scale. you just might hate everything charge related if you have to go back to the drawing board to include a charger after the matter to get the 1/8 going and do other classes as well
