How to test sensor operation TEKIN RX8
Just wondering if there is an easy way to determine sensor operation without unsoldering.
I have 2 SCTE trucks both RX8's , one with 4600kv very smooth take off, neither have any cogging issues Other with 4000kv seems to have very abrupt start up, like 1/4 throttle right now. Thanks Al |
On the Tekin RS and RS Pro if you squeeze the throttle slightly, three lights dimly light up indicating proper sensor array performance. Don't know if RX 8 is the same. You might check the Tekin website for FAQs or the instructions for the RX 8. This info was in the instructions for the RSs.
Spn the motor shaft by hand. The three lights on the right should lightly blink. Helps if its a bit dim, as they dont light up brightly.
Originally Posted by Hoese37
(Post 12372108)
Does that mean its the motor? or ESC? |
is it possible to turn the sensor feature off/on in the programing?
The RX8 will run either motor. Itll look for sensors. You probably need a new sensor board. They are pretty cheap and easy to change.
Thanks very much for your help, found a board $22.50
| All times are GMT -7. It is currently 02:54 AM. |
