-   -   a good power supply? (https://www.rctech.net/forum/radio-electronics/742306-good-power-supply.html)
yamahabanshee 07-05-2013 09:37 PM
Hyperion-EOS-720i-Net3 I charge 2s to 6s 5000mah lipos. Thanks.
Dave_S 07-05-2013 10:10 PM
The little trakpower supply that comes with vr-1 combo would work pretty good, it will do 20 amps, I am currently using one with my icharger and it works fine, or for a decent amount cheaper you could use a computer power supply
yamahabanshee 07-06-2013 07:18 AM
If I was to get a power supply to large could it mess up the charger? Thanks for the info by the way.
Dave_S 07-06-2013 09:33 AM
No, it won't mess up charger. A power supply could be capable of 2000 watts but if your charger only demands 150 watts your power supply wouldn't even know. Potential for damage could be the voltage, looks like that charger has an input requirement of 10.5-29 volts DC, so as long as your power supply provides that your good.
one8updragracer 07-06-2013 12:04 PM
http://www.feathermerchantrc.com/
I got the 12V 47A version. works like a charm.
Dave H 07-06-2013 04:07 PM
A 0720i Net3 and not a Net3-AD right? Meaning the DC only one?
What charge rate (amps) on the 6S and other larger lipos are you looking for? If you want to get full power, which would be around 10 amps on a 6S, you need a power supply of over 14.5 volts, ideally with at least 340 watts of power. A 12V supply won’t allow the charger to achieve full power, perhaps around 8 amps on a 6S though.
Here is one possibility, seems to be reliable and is about as light and small as I have found in this power range. Just remember while the slightly higher voltage works well with that charger it may not work for other stuff designed for the more common 12-13.8V supplies.
JUNSI P350 POWER SUPPLY
Devigili22 07-06-2013 05:43 PM
Grab one of these and follow this.
apriliamille 07-06-2013 10:12 PM
6s 5000 lipo. id look for the highest voltage possible in a psu
http://www.progressiverc.com/iota-dl...er-supply.html
http://www.amainhobbies.com/product_...y-27V-20A-550W
dont fall for 30 amp or 40 amp power supplies with that charger it adds price to the psu and the charger wont use it (unless you want expansion in the future for a bigger charger)
Pellefa 08-31-2013 12:18 PM
Picking of on the "good power supply" theme;
I am charging 2 1/10 2C powered cars at the same time on a dual charger, and the 350W power supply I use is just huge, and I figure I could go down to 200W roughly..
So, anyone knows about a compact 200w-ish quiet power supply...?
Andy Koback 08-31-2013 01:04 PM
nitrorcthunder.com has a very nice 30amp w/adjustable voltage output. 3 terminals. Sell for $65 w/free shipping. Got 2 and love'm both! :nod:
hyujmn 08-31-2013 04:56 PM
I got one off a guy here on rctech for $50. 69amp 875watt converted server PSU. A little loud, but I most certainly do not lack for amperage or wattage.
jrmarquez.702 08-31-2013 09:08 PM
I use the Protek super pro 1000 and the Protek 620 prodigy. I can charge two lipos at 20amps each. I looked into the computer ps's and didn't like the mess, I wanted something cleaner. Been great for over a year now.http://i769.photobucket.com/albums/x...psb273f538.jpg
BlueGlowBoy 08-31-2013 09:18 PM
+1 on the Protek. I have the smaller one and was powering my LRP Competition Touch, plus two AC6 chargers with zero issue. Have also let a friend use it with his fancy dancy hyperion while I was using my LRP charger. No problems, and it's 3 years old.
