550 2 pole -vs 4 pole motors. Any good discussions?
#16
Have you given any thoughts to the newer Pro4 HD's? I'm running a 550 4.5T 2 pole in a SCTE and a Novak SC Pro ESC. 1st runs at the track lacked low end to clear jumps with little runway (geared 13/40). I've since then retarded the motor timing (on the can) and increased Min Drive on the Novak to 6. Heading to WCRC tonight to see if it makes a noticeable difference. If I don't find the low end I'm looking for I'd like to get into another 550 can. I just don't know if I should go lower KV (~3500) or 4 plole 550.
#18
I have done the testing on a HIGH grip carpet track. My testing has yielded that a 540/545 4 pole motor creates MORE stress on the rest of the power system. This stress being MORE HEAT in the ESC and battery. ESC temps were at least 15 degrees higher, battery temps were 10 degrees higher while pulling way more mAh out of the pack. All tests were done with 2 IDENTICAL batteries from Psycho Cells Racing. As far as speed and torque, all that needs to be done is make slight adjustments to the ESC boost and turbo timing as well as punch. My current SCTE 2.0 is powered by a Hobbywing V2.1 and a Novak Ballistic 4.5T 550.(YES IT WORKS AND NO IT DOES NOT OVERHEAT THE ESC) ESC temps after a 8 min main are 110-120 degrees. Battery temps after the same main are 105-115 degrees.
#20
Right...I forgot...
Current Hobbywing V2.1 in my truck has been slightly modded. I replaced the shit stock HW fan with a WTF(Wild Turbo Fan) 3010 which is a bigger overall fan that produces MORE CFM and RPM. Secondly I added a 5600uF "glitchbuster" cap to the battery inputs on the ESC ALONG WITH the factory 2 cap bank. Overall power is insane. It has the about the same amount of torque that a Pro4 HD produces and MORE torque than a 540/545 4 pole. Physical motor timing is still stock at 30 on the endbell with 10* of boost timing with an additional 5* of turbo timing.
#22
There are a lot of variances when it comes to capacitors, such as the caps ESR values which would have to be taken into consideration.
There are a couple different electrolytic cap manufactures, with some better than others in quality and impedance claims.
My caps also are run with a schottky diode in parallel as well. Something all cap packs should have. Most of the better cap pack manufactures have them soldered on their SMT boards.
Not doing this can allow spiking to occur, which in turn can give you a false sense of heat measurement since it would have run cooler had it not reversed polarity when under hard loads, causing said current spiking.
Point blank, the cap packs are always going to help your system no matter what.
#23
Temping a capacitor doesn't tell you enough of the story in my opinion to even be worth doing unless you know a whole lot about the specific caps.
Capacitors used by ESC manufacturers on their ESCs are Low ESR. They generally cost more than caps that are not Low ESR and there is really no reason for a supplier of "Glitchbuster" caps used in receivers to use Low ESR caps for this purpose since the voltage fluctuations have a much lower frequency.
If the Cap used on an ESC is not a Low ESR cap it will me mostly ineffective since it can't counter the the voltage fluctuations that occur at the PWM frequency as well as a Low ESR cap. But if it is not Low ESR those voltage fluctuations would still be trying to push current in and out of the cap against the higher resistance, leading to more heat in the cap.
So there is a reason to temp the cap.
And that's also why I asked if there was a back-to-back test with and without the cap but no other changes.
