KO Propo RSX Servo not working well with Futaba 4PKS-R >
Old 06-27-2013, 04:40 AM
Default KO Propo RSX Servo not working well with Futaba 4PKS-R
Dear all,
lately i have been running KO Propo RSX servos with my Futaba $PKS-R System as it works wonders, until last week i.e.
we where racing and wanted to slow down a bit the steering from the st-speed menu.
it was set 80 turn and 80 return and went down to 70 on the return.
Tested the steering and after a couple of steering movement all of a sudden the wheels started shaking (servo was moving to the right and left in a loop).
Went back to 80 / 80 but still had shaking after a couple of steering moves.
Had to totally remove the setting from the ST-Speed
I have tested all possibilities and seems like its a servo issue as when i swapped servos nothing happened.
I also noticed that when i set the remote to the old system C1 it worked flawlessly.
what could be the issue as i really need the ST-Speed setting to work normally.
speed6 is offline
