TORO TS 120A ESC
#151
I bought this esc with the believe that it would work on a 4-pole motor sensored. I wanted to add some turbo for more main speed. It doesn't so I am running it now sensorless and my motor doesn't have endbell adjustment. On my sct-pro the motor ran cooler with timing but I like the lower weight and size of the esc.
Hopefully they will add 4-pole functionality in sensored mode as a lot of manufacturers are putting out sub 550 4-poles out. Orion and Tenshock for instance.
Thanks for trying to help!
#152
#153
I run the toro sc120 with a 4000kv 550 in my scte and the only thing i would want more would be the ability to run sensored. I got mine as a combo with a 4600kv for $103 shipped from japan to my door. it comes with a programming card but usb/pc programming would be nice too.
All told i'm very happy with the combo. just wish i had gotten it with the 4000kv instead of the 4600kv, since we've moved indoors to a virgin clay track that is smaller then the outdoor track which has closed, I had problems keeping the motor cooler. It was running at 150-160 after 6 min. the 4000kv comes of at 130-135 after 6 min.
Still running strong after weekly abuse.
#154
SkyRc themselves said it doesn't run sensored/advanced timings with 4-pole. My speedo doesn't even turn on with the sensor cable attached. Yea it's the newest 1.05 or something. Unless they updated a week or so ago.
#155
Ok I will address this with my skyrc rep to get some clear answers and hopefully if they are working on a resolution if needed.
#156
#157
Nano where did you get your esc from? Is it the plastic or Aluminium model. Also I have run into cases where people will email skyrc with a question a get the wrong information. I have spent several months and countless hours on skype with my rep working with to be better with communication, product release, product improvements, better documentation and countless other items. So I will do all that I can to bring clear and consistent information to all of their products. So please don't hesitate to ask.
#158
Hi guys,
I have just bought the SkyRC 120 SCT blue version for my Durango DESC410 short course truck and are having a strange issue that maybe you guys could sort out for me.
The motor is a Skyrc 5,5 SC 4000kv motor with sensor. Everything is working perfectly good when the batteries are fully charged but at the end of my pack the problem is getting progressivly worse as voltage drops from the batteries.
I am running a cutoff voltage of 7 volts and the issue is that the motor/ESC starts cogging and sometimes it will not even get the truck moving.
You have to be really carefull on the throttle to get the truck moving. This is as I said only an issue when the battery voltage is begining to drop.
Do you think it is because the voltage cutout is manually to 7 volts?
I like to preserve my batteries and have about 20% percent left when cutout occurs, any lower setting and the battery is way to much depleted. Any other setting I could try to get rid of this issue? All other values on punch and turbo is default..Please help as this issue is really getting on my bad side and I hate that because I really like the ESC otherwise.
Software is updated to latest 1.07
#159
Hi guys,
#160
I have it connected to a HW 4-pole 4000kv motor. Bring it: Are you sure that the Tenshock goes into boosted? The red light is constantly on? Maybe it's just a problem with HW 4-pole? It's more of a 545 formfactor. I tried it also with a SKyrc SC speedo with turbo (that worked) but had a brainfart moment and burnt the speedo with my IP lipo.
#161
can someone please explain the turbo engage and disengage slopes
the esc lets you go from 1deg/0.1S - 64deg/0.1S (in 1° increment)
now the question i have, if i set the setting to say 30deg at 0.1s for both engage and disengage will this be quicker or slower then if i was to make it 50deg at 0.1s for also both.
#162
Hi guys,
Voltage cutoff to 6.0
With this motor you will need to be sure your batteries are up to the task. My guess is that this is the culprit. Turnigy nano 65-135c should take care of it.
#163
Thanks Dan,
Yes I am pretty sure you are right about the cutout, but taking the batteries that low will damage them, in my opinion...
Is there any way one can get main battery voltage telemtry on the DX4s radio using the SR410 rx?
Thank you for your help
#164
I have always set my lvc to 3.0 or 3.2 per cell regardless of the esc brand or model and I have yet to damage a battery. The higher demands of a SC pull the voltage down on a battery further on acceleration than most other platforms. It is because of this strain on the electronics that SC's are very hard and kill batteries. What capacity batteries are you running?
#165
Running the cutoff at 7v? I hope you mean 3.5 per cell. I run my lvc at 2.8-3.0per cell . your cogging issue is your lvc working. So its not cogging. You have an improper lvc setting. Also change out your sensor cable if it is still happening after you change the lvc. And get rid of any bullets if you have them on the motor wires and solder directly to the motor tabs.
