Rough start with brushless motor
I have a rough start with my reventon pro and 17.5. I have changed sensor wires, checked soldering and charged batteries. What is causing it? I have a YouTube vid
http://youtu.be/KQtKu9iPllQ |
Originally Posted by hanzo3
(Post 12115162)
http://youtu.be/KQtKu9iPllQ Try to redo the solder joins again, maybe you have a buddy that could help out with them? dry & poor solder joints will cause problems on their own. Cheers Rob. |
check ur A-B-C wires make sure the correct wire is on correct tab,, and Remove all soldered wires clean grind down all the excessss solder and REDO.. try a Hotter solder iron somewhere in the 45watt + range..also check esc cap units solder .. Recalibrate ur ESC to radio..
sorry man not to be downing u but the solder joints look not so good at all.. Try reading this..http://www.speedpassion.net/uploadfi...0thAug2012.pdf not sure if u have a link.. what color leds are light on esc???.. |
Red and orange are blinking. I will redo solder. I have it set at 700 on my iron.
Blinking red led means low voltage.
Blinking orange led means over heating esc. I could not find anything for the combination of the 2 leds blinking. http://www.speedpassion.net/uploadfi...0thAug2012.pdf I agree with the guys posting about the solder joints, cold or dull solder joints can cause these problems. |
| All times are GMT -7. It is currently 11:42 AM. |
