Orion RS Pro Problem
Hi,
I am using an Orion RS Pro together with a Hacker 4 Pol motor in my Durango 4WD SC (software version 1.71). I tried the 4pol Firmware and the stock one. With the stock firmware i can go much faster... But the reverse does not work with both firmware versions... And the car just does not roll very long, it is like if I use a dragbrake (but it is set to 0!) Please help me |
Are you running the 2-3s System or the 1-2? Which Model? Also, is the setting on your radio adjusted proper? My advice to you would be to reset everything back to stock/zero settings and start from the bottom up. Ive been running the New Pro Orions since they came out and have never seen that issue.
It almost sound like a Cog issue with the motor though. Ive seen Castle systems do that due to lack of power being pushed through the motor, hense the reason I asked about the esc. Also make sure your battery is fully charged. Sometimes the basics can be too basic.. |
Originally Posted by k1ller rc
(Post 12091326)
It almost sound like a Cog issue with the motor though. Ive seen Castle systems do that due to lack of power being pushed through the motor, hense the reason I asked about the esc. Also make sure your battery is fully charged. Sometimes the basics can be too basic.. It is the 2-3s Orion R10 Pro (160A max). I will try to set everything back, maybe this will help. Does anybody maybe have some other advice? |
| All times are GMT -7. It is currently 04:17 PM. |
