Team Orion advantage touch. Help Needed
Hi Guys.
So I just got this charger in the mail today, and I was very excited to try it out. I took out a 2cell 5600mah Lipo, plugged it in, and selected charge. It worked perfectly. I stopped the charge, and selected Discharge instead. I selected a discharge rate of 2A (max). The charger won't discharge with a rate of more than 0.6A??? (The battery is almost full) I have tried storage mode, same result (0.6A) My question is why? Is this normal? I thought it would shoot straight to 2A... Same thing with a 1600mah Nihm reciever pack. Only a discharge of 0.6A Software is 1.5.... Any help/advice // Chris |
The discharge is also limited to 5 watts of power. 0.6 amps is about it for a typical 2S lipo near full charge. It should go up a little as the pack voltage drops off, but not much.
Not uncommon, many if not most lipo chargers have limited discharge capability. |
Thank you :)
You're welcome. Cheers
| All times are GMT -7. It is currently 01:24 AM. |
