-   -   Pit Light Help??? (https://www.rctech.net/forum/radio-electronics/721205-pit-light-help.html)
DR STATIC 04-10-2013 07:58 PM
Pit Light Help???
3 Attachment(s)
I have a Specs Competition Performance Light. I just got this light as part of a lot sale. It is aluminum and carbon fiber, but I need a power supply. Also does anyone have any information on it. I've had no luck on-line.
Thanks.
Voltage_Drop 04-10-2013 08:26 PM
What is that little box in the bundled up cord? Looks like a PSU, does the cord detach from the light? I think that's the power supply there, and if so then look at the model # on it. Or see if you can find a model # on the light to narrow down your search options.
If all else fails, you can use a lab power supply to power anything within its specs. You would just have to know the voltage and current input of the device and have the appropriate connectors.
DR STATIC 04-10-2013 08:54 PM
The box is the power switch. No model number. The unknown factors are the reason I'm looking for data. I'm also hoping to find another owner, to gain insight.
sschultz 04-10-2013 11:11 PM
http://www.rcplanet.com/ProductDetai...e=INTC24353RED
TOM MAR 04-10-2013 11:23 PM
Looks similar to these...
http://www.integy.com/st_prod.html?p...01&p_catid=167
http://www.integy.com/st_prod.html?p...16&p_catid=167
coaltrain 04-11-2013 03:21 PM
http://www3.towerhobbies.com/cgi-bin...?&I=LXBWHZ&P=7
asc6000 04-12-2013 11:09 AM
wow, pit lights are wayy overpriced, and with that angle how the heck do you get it to shine down on the car ? the light is on the backside of the car and not the front where you are working .. ?? I don't get it.
This one you can light up your car where you need it and it's $20
http://www.premdesign.com/rel_tuts/lamp_overview.jpg
DR STATIC 04-12-2013 11:49 AM
That is great. I'm simple though, I'm using a set of shop lights about 3 to 4 feet off the top of an old military desk. Plus the room lights, works for me and I'm not fighting a table top lamp.
These are table pit lights. They're small, compart, and bright. This one takes up very little space. I'll probably sell it though, I have a Ott-Lite and the SPECS is new. Better resale value in the SPECS being new.
Thank you for everyone assistance. I was hoping to find an owner because it might look similar to the Intergy, it is not the same. It would appear that the Intergy is a copy.
Hoese37 04-12-2013 11:53 AM
Im gonna assume there all made in the same place, just rebranded. SPECS, Muchmore, Integy and Orion all have the same setup.
EricW 04-12-2013 12:14 PM
Where do the ballcups go?
