Lipo Charger
What is a good lipo charger that is popular? I want to get some input on a good charger that is reliable, popular, and not to expensive. I currently have a traxxas ez peak plus charger that I like but I feel it takes FOREVER to charge a battery.
Originally Posted by austinspeer810
(Post 12022469)
If you don't like waiting between runs, buy multiple packs. |
Originally Posted by pablo040
(Post 12022654)
Changing brands of chargers is not, or it shouldn't, decrease the time it takes to charge a battery. Modern batteries, especially LiPO packs, should be charged at 1C (or 1amp per 1000mAh of battery pack rating) - so be prepared to wait.
If you don't like waiting between runs, buy multiple packs. What battery are you using? |
First things first...how much are you looking to spend? That will determine the quality and speed of your charging needs. A high quality charger with the proper power supply will get you accurate and safe 3c charging capabilities.
A good quality charger that can go higher than 1c rate will be 100 bucks and over. Most of them are DC only, so you will need a power supply.
I suggest looking at Progressive RC They have many different chargers and power supplies to choose from. They have combo deals with cases, and calculators so you can figure out what type of power supply you need to charge at higher rates and with multiple cells. |
