Originally Posted by MTown701
(Post 12003454)
Hello. I have the Castle Creations Mamba Max Pro ESC with the 1410 3800kv motor. I am confused about the maximum voltage that this comba can take. I know for a fact that the Mamba Max Pro will handle 6s without a problem. The motor can states that it will handle 3s lipo max, but the maximum rpm is 100,000. With 3s it will only get 47,880 RPM. I am wondering if it will run on 4s. On 4s it will run at 63,840 rpms. Still under the maximum rpm. Technically it can handle 6s at 95,760 rpms it that maximum rpm is correct. Will it be ok to run on 4s just for speed runs?
Thanks! |
| All times are GMT -7. It is currently 07:02 PM. |
