Who charging 20+ amps or more now?? >
Old 04-13-2013, 03:58 PM
  #181
bvoltz's Avatar
Trader Rating: 44 (100%+)
In my search for a "cash box" to charge in, I did find at the local Meijer on clearance, a metal lunch box for 8 dollars... I purchased a Marilyn Monroe lunch box... So do not rule out the a metal lunch box. I will be using this for storage at home also....
bvoltz is offline
Old 04-13-2013, 08:32 PM
  #182
Team Grid RC's Avatar
Be sure that it is made of steel or stainless steel and not aluminum. Aluminum has a melting point of 1200F, and what I have heard, a burning Lipo temp can reach 1000F. In a confined space, it could be higher.
For storage purposes, if it is made of aluminum, multiple bursting Lipos will surely melt it. For charging it may survive a single Lipo fire.
For storage I use several ammo boxes and spread out the Lipo inventory. This way, if a Lipo ruptures, it does not destroy your whole collection of Lipos.
Team Grid RC is offline
Old 04-13-2013, 08:51 PM
  #183
bvoltz's Avatar
I just looked up the melting point... I guess I just wasted 8.00, rather this then the other option... Man I was so looking forward showing up to the track with my Marilyn Monroe lunch box....
bvoltz is offline
Old 04-14-2013, 07:39 AM
  #184
bvoltz's Avatar
Question - How often are you balance charging?
bvoltz is offline
Old 04-14-2013, 07:48 AM
  #185
Your Marilyn Monroe is probably big enough to also fit a lipo sack inside of it. You can double up a safety factor by doing that with style.
Old 04-14-2013, 07:49 AM
  #186
You should balance charge every time.
Old 04-14-2013, 08:52 AM
  #187
bvoltz's Avatar
Thanks - That is what I thought but wanted to verify....
bvoltz is offline
Old 04-14-2013, 08:55 AM
  #188
bvoltz's Avatar
I agree and can. Just wanted to be safe at higher charging rates... I'm now looking for a stainless steal box. Even good cells can go bad... so no need for say 20 or 30 cost is a very small cost compared to the damage that could be caused by a bad cell showing up, with any battery...
bvoltz is offline
Old 04-14-2013, 09:29 AM
  #189
Mr RCTech's Avatar
Originally Posted by SS LS1
Does one high amp charge cycle refresh older packs for just that one discharge cycle only ? Or does one high amp charge lower the IR somewhat permanently so future 6-10 amp charging will also show improved output for awhile?
Yes.
A 6-10 amp charge will not improve the IR as a 20+ amp charge would do.
The lipo batteries respond to the higher charge rate better....
Cycling your lipos to lower the IR may work at lowering IR somewhat but doesn't lower the IR as a higher 20+ rate.
The 45 minute low charge rate must cool the pack down to much???
The 20 or higher amp charge decrease IR dramatically just on the first charge.
I did notice having a older lipo pack in store charge for a month discharge at a lower IR after being charged and run at a higher charge rate once.
So the cells seams to be getting better.
Don't know why, but it works...
Mr RCTech is offline
Old 04-14-2013, 09:35 AM
  #190
Mr RCTech's Avatar
I agree and can. Just wanted to be safe at higher charging rates... I'm now looking for a stainless teal box. Even good cells can go bad... so no need for say 20 or 30 cost is a very small cost compared to the damage that could be caused by a bad cell showing up, with any battery...
Alot of guys will use a small Ammo can.
You can buy one cheap at a Army surplus store.
Old 04-14-2013, 09:42 AM
  #191
Ammo boxes at home are ideal, but a steel Marilyn Monroe box looks better at the track!
Maybe skin makers can make wraps for ammo boxes so they could look nicer at a track.
Old 04-14-2013, 10:19 AM
  #192
LOW ET's Avatar
Trader Rating: 109 (100%+)
ammo boxes are the best choice.
LOW ET is offline
Old 04-14-2013, 12:21 PM
  #193
speaking of lipo boxes: http://www.liverc.com/news/special_f...inment_System/
JiuHaWong is offline
Old 04-14-2013, 12:35 PM
  #194
DarthRacer's Avatar
Originally Posted by JiuHaWong
That is pretty neat. Wonder what the retail is on those.
DarthRacer is offline
Old 04-14-2013, 12:57 PM
  #195
http://www3.towerhobbies.com/cgi-bin...P?I=LXCULN&P=8
