-   -   help with sworkz s350 be1x esc programming pls (https://www.rctech.net/forum/radio-electronics/717352-help-sworkz-s350-be1x-esc-programming-pls.html)
redtags 03-28-2013 10:18 AM
Hi, anyone use this sworkz rtr unit ?
I'm stuck in first mode setting esc , pls assist me with step by step to enter 2nd or 3rd esc mode.
I tried following the instruction sheet, but the red led never blink 2 or 3 times as per instruction.
always in 1st mode.
Anyone using this pls assist me. Thanks alot ..
Sorry, the correct type should be Sworkz BX1 E
hpikillr 03-28-2013 11:33 AM
try redoing many times..
if that will not work.. try switching throttle from Forward to reverse on RADIO.. try setup this way..
tried looking for setup instructions with Zero luck.. Next step call customer service..
redtags 03-28-2013 09:26 PM
1 Attachment(s)
Hi Hpikillr,
Thanks for responding.
I scan the instruction sheet.
I'm stuck in first mode (max braking force).
I can not move to 2nd, 3rd, and so on mode to program each setting. I read instruction sheet and tried programming the esc for almost an hour with no result.
I should have the RED LED blinking 2 times for 2nd mode, 3 times blink for 3rd mode, and so on right ?
Here's what I tried,
1. Press set button then power on
2. Yellow led blink with 3 beeps, then red led blink 1 time.
If I press set button and hold, I'll enter 1st mode setting right ? ok so far so good.
But after step 2 above, if I tried to enter 2nd mode with short press on set button, nothing happened. The red led never blink 2 times.
I tried reverse mode throttle, not working. Tried calling customer service, they dont speak english. My email also got no reply so far.
My only hope is from you guys ... Could someone that might have the same kind of esc setting steps share their knowledge and tell me where did I do wrong ?
redtags 03-28-2013 09:36 PM
1 Attachment(s)
this is how the esc looks like. any similarity with other esc ?
ASA 10-31-2014 12:01 PM
Sorry to dig out an old forum but also have just picked up one of these with a few upgrades on the cheep:) I have the info to set up esc but no info on the first stage of setup( setting endpoints-forward,neutral,reverse) can anyone help out with some info to do this?
Cheers Aaron
ASA 10-31-2014 12:06 PM
I forgot to mention I am running spektrum radio gear and not the original rtr radio
Cheers Aaron
