Tekin RS, Redline 17.5T no brakes ? >
Old 03-27-2013, 12:37 AM
Default Tekin RS, Redline 17.5T no brakes ?
I have just finished building my Sakura, have a Tekin ESC and a Redline 17.5T motor, I am using a Futaba MX. I have done the radio calibration on the Tekin, have the motor setup with BL fwd/brk/rev delay. Everything works fine but the brakes seem to be very weak ? have set brake on the hotwire to 80% so not sure what the problem is ?
DJDINO is offline
Old 03-27-2013, 12:44 AM
Odin544's Avatar
Trader Rating: 93 (100%+)
Endpoints set at 100 on the radio? I always set the brakes at 100 on the hotwire and turn them down on my radio if needed. I have a 4pksr. Not sure if you can do that on your radio though. The other thing to consider is if the motor is used or ever gotten hot (>180 degrees) before you could need a new rotor. If a motor gets too hot the rotor looses magnetism. When you loose that magnetism you will notice it first in the brakes from my experience.
Odin544 is offline
Old 03-27-2013, 01:41 AM
Yes mate all EPA for throttle and brake set at 100 on the Tx, motor and esc are new. I'm a bit lost now, if I put it in reverse and hit forward it stops as there is no delay, I can feel a small amount of brakes but at low speed they do SFA, so at speed I have a problem.
I had to reverse esc function on the Tx as forward and reverse were around the wrong way initially, though don't think this effected anything.
DJDINO is offline
Old 03-27-2013, 02:10 AM
Odin544's Avatar
What surface are you running on and what software version in the esc?
Odin544 is offline
Old 03-27-2013, 02:29 AM
Just a carpark basher ATM, I have just downloaded the current firmware from Tekin. Should I just run it as fwd with brake and delete the reverse ?
DJDINO is offline
Old 03-27-2013, 02:45 AM
Odin544's Avatar
You could try it. Turn the active braking on and see if that helps first.
Odin544 is offline
Old 03-27-2013, 03:39 AM
OK have turned active braking, brake minimum and brake strength to 100, one thing I've noticed is the quicker it's going the better the brake works, at slow speed they take a while to slow the car ? I still have brake drag set to low.
Thanks for the input Odin544 it is appreciated.
DJDINO is offline
Old 03-27-2013, 04:59 AM
Suspended
re-calibrate.. i have seen this take many times b4 all is good.. it has a proportional braking on the rs.. also set brakes at MAX 100% then fine tune on radio..
hpikillr is offline
Old 03-30-2013, 07:57 PM
Farticus's Avatar
I had the same issue and turning on active braking made all the difference.
Farticus is offline
