Orion R10 Pro and 4 pole motor users....... >
Old 03-26-2013, 06:25 PM
  #16
J-Fraz203's Avatar
Originally Posted by Losi57 View Post
Frazz i know there was a problem with the firmware when running this esc with a 4 pole.You need to make sure V1.71 firmware is downloaded.Just google Vortex r10 pro 4 pole software.Hope this helps!
I have the 1.71 software and that's the issues I'm having. I have googled it but couldn't find any issues. The esc works fine on any other software I use even if I crank the timing wich would in turn take more power from the bats wich again are not the problem.
J-Fraz203 is offline
Old 03-27-2013, 05:51 AM
  #17
J-Fraz203's Avatar
Up for some help
Old 04-02-2013, 11:58 PM
  #18
Tim Stamper's Avatar
After extensive testing with the same setup, I gave up.
I had 2 R10 pro's do the same thing, programmed them both with 3 different computers and used 2 different programmers on them. I used a Pro4 4000 and a Pro4 4600 and no matter what I did, it browned out randomly and in different spots on the track.
I consulted a local Orion driver and they heard of the same problems with 4 pole motors. I had everything shut off in the programming and I also tried it with the settings cranked, it did not change a thing. I plopped in a 2 pole motor that I borrowed and off she went.
I tried the stock software, mod software and the 4 pole software and although they all eventually failed, stock and mod seemed to fail less frequently.
My only issue is this, I would like to run an Orion 550 but cannot find any. Too bad, the car now sits while I wait.
Tim
Tim Stamper is offline
Old 01-02-2017, 04:19 PM
  #19
Default Fixed?
Anyone know if this was resolved? AKA is tekin pro4 HD sensored suitable for r10.1 with current 4 pole software? Anyone running this set up? I'm new to SC and I have this esc already and would love to use it. Or anyone have exp with Orion's 550 motor with r10.1?
teekv1 is offline
Old 01-10-2017, 08:34 PM
  #20
Trader Rating: 32 (100%+)
I have orion r10.1 pair with orion 550 2pole without any problem. Today just switch to my back up motor 4pole LRP 4700kv motor works flawless make sure you upgrade your ESC software to 4pole if you want to pair with 4pole motor to your orion r10.1 ESC.
raved007 is offline
