Mamba Monster Switch Removal >
Old 03-15-2013, 06:25 PM
Default Mamba Monster Switch Removal
Hello. The switch on my Mamba Monster failed so I had to remove it. I removed it by just desoldering the wires and putting a little bit of solder in between the two contacts. Should I have kept the wires in and soldered them together and put shrink wrap on it? It is the old V2 so it probably isn't covered under warranty.
MTown701 is offline
Old 03-15-2013, 09:30 PM
i cut my wires and soldered them together as i didnt want to mess with the board. if yours is working fine i wouldnt worry unless you are worried you screwed with the possibility of warranty issues ?
in that case i do not know.
twisted is offline
Old 03-17-2013, 10:24 AM
JustinThyme's Avatar
Trader Rating: 23 (96%+)
Should be fine.
Castle uses cheap switches and often the failure is the crappy solder job. Ive had two fail, one just from the junk swicth and the other was the solder job. Pulled the outer case, slid back the heat sink and the wire ws soldered in a loop around the contact but not to the contact. First order of business for me became to remove the cheap switches and replace them with a quality switch.
A lot run without the switch but I prefer to be able to turn the ESC on/off in a quick manner if needed.
JustinThyme is offline
