-   -   mamba monster esc not working (https://www.rctech.net/forum/radio-electronics/710446-mamba-monster-esc-not-working.html)
MEOWMEOW 03-04-2013 06:39 PM
two of the receiver wires came off the esc i managed to get one soldered and all i need is the brown which i think is ground. it just wont solder on. how can i connect it to get it working again worked fine before this happened. i bought it used so i have no warranty for it and i dont wanna go to the point to pay the 70 and have castle do it. any help is greatly appreciated
thanks
MEOWMEOW 03-06-2013 04:37 PM
No one has had this happen to them?
huzzler 03-07-2013 01:20 PM
Not sure what you mean by receiver wires coming off? Did they come unsoldered from the board? Maybe you just need a better solder iron. Some of the low wattage irons don't get hot enough.
MEOWMEOW 03-07-2013 03:37 PM
Yes the wires came off the soldering board. As for the iron it has multiple settings as to how hot it gets I believe it goes to about 700degrees and i have battery wires from the mamba monster very easily I don't see how these thinner ones need more heat I also use flux but still nothing. I believe the little piece that needs to be soldered to came off the little tab because the other wire soldered fine. Is there another place I can use to solder it to and get ground connection?
nexxus 03-07-2013 07:06 PM
If the solder tab has come off the board it's curtains!
