Charging 2 - 1S/2S/3S batteries with a one port charger
From what I understand, if all the maH ratings are the same, the batteries are within 0.5V of each other, and the S rating doesn't exceed the charger's max cell count, two batteries can be charged at the same time. I wouldn't do this but only so often if I didn't have time. How would I go about doing this? I'm a little confused on how they are hooked up to the charger.
Suspended
just make a splitter.. like people use on erevo and the like to put 2 batteries in series u just want 2 batts in parallel.. if u are using deans thats 2 male plugs soldered to 1 female plug
Dave H and JohnySplits,
What I'm getting is:
I can charge pretty much any set of lipo batteries, in any maH, as long as the cell count is the same and the total maH rating is set in the charger. Correct?
Johnny, wouldn't it be better to connect the battery main leads before the balance plugs? I'd be concerned that the current surge as the packs balance in voltage could be too much for the small balance wires.
Ok, i've checked this out with revolectrix, iCharger, and a few other different sources. All agree to connect balance plug first, then discharge cables. The idea is that when you plug the balance connector in first, the cells within the pack will equalize themselves. Im not an electronics expert, but they are so this will be my lipo connection procedure from now on.
Not really true, you just charge at 1c rate for both packs combined. Example would be 2x5000mah packs parallel charged is the same as charging one 10000mah pack. So you set the charger at 10amps for a 1C charge rate.
