ezrun esc problems
hi all,
i'm running an ezrun esc/brushless motor setup. i've got a couple of cars with this setup. one drifter a streeter and a crawler, all have been good with no dramas. just got a new one for the new crawler i'm building. got it in and set it up as normal....throttle position(throttle neutral, full forward and full brake)...and all my program card entries..all fine. the trouble i'm having...will go forward on first throttle after turning on the esc, once i have hit brake/reverse it will not go forward again!! will brake and reverse every time but no forward. when you put trigger to forward both the red and green led flash at the same time but no power to motor. turn the speedie off and on again and same thing...all the forward you want until the first time i hit brake from that point on nothing. i'm no noobie,i've tried all the normal checks, connections, reset throttle limits again, even tried programing the different run options (forward/brake..forward/brake/reverse..forward/reverse)..everytime same thing. i have never come accross the red/green flashing at same time before on any of the other cars. any ideas?? have i got a dud esc? remember it is brand new. cheers in advance |
| All times are GMT -7. It is currently 09:14 PM. |
