-   -   Problem: Connecting batteries to buggy (https://www.rctech.net/forum/radio-electronics/697353-problem-connecting-batteries-buggy.html)
RCspecialist 01-20-2013 08:51 PM
Hi (Again)
I am getting the XTM XT2e soon and I need to get some batteries for it, unfortunately the ESC uses 4mm bullet connectors and the batteries I want to get use 5.5mm bullet connectors. Are there any adapters out there that will allow me to connect the battery to the ESC, or do I have to make my own? And if so, any advice on how to make an adapter?
rcduder 01-20-2013 09:01 PM
Originally Posted by RCspecialist (Post 11705086)
Hi (Again)
if I was you I would just put the correct size bullets on the esc, this would be the quickest and easiest way rather then makig your own connector or finding some sort of adapter it's easier and probably cheaper to order a couple of the correct size bullets
RCspecialist 01-20-2013 10:15 PM
Yeah thing is, I don't have a soldering iron and I don't know much about wires and connectors, I don't want to end up cutting to much or fucking up the wires, and I definitely don't want to have to buy another ESC which is worth $170, I don't have that money.
sunco1 01-20-2013 10:37 PM
My best advice to you is to invest in at least some type of soldering iron. Running electric cars, you need to have one. I think all rc'ers should have one. They aren't expensive for a decent one. Then solder the right plugs on.
But if you are that concerned about it.. find batteries with 4mm plugs. Gens ace are good cheap batteries with 4mm bananas.
If all else fails bring it to your lhs and have them do it.
rcduder 01-20-2013 10:58 PM
yup your lhs I'm sure would be more then willing too help, usually all hobby shops have a working soldering iron fo customers to use or for hem too use on customer rides. and yeah some 4mm bullet batteries would be better as that's usually the standard for lipo batteries. well said sunco1
RCspecialist 01-21-2013 02:40 AM
Yeah I had really only been looking at turnigy batteries, nothing else, but the turnigy nanotech have 4mm bullets so I will look into something like them. Thanks guys.
RCspecialist 01-21-2013 02:44 AM
Yeah, I will eventually have to get a solder, its useful in so many ways. But I don't need one right now, so I will get it some time down the track.
hpikillr 01-21-2013 04:20 AM
info
XTM XT2e 1/8 RTR Brushless Electric Buggy w/ 2.4Ghz Airtronics
Airtronics 2.4Ghz Radio system. Fully programmable, 10 model memory. Transmitter uses 8 - AA's.
2370 KV brushless motor & 120A Speed controller. Comes with programmer for ESC as well
Metal gear servo.
ESC uses 4mm bullet connectors to go to batteries. You will need to buy\make a series adapter to hook up 2 - 7.4v LiPo's (Not Included)
Think ur info is off this buggy uses 4mm conections..
RCspecialist 01-21-2013 04:35 PM
Metal gear servo.
Yeah I know about the buggy.
